11-28-2006 01:40 AM
I receive a mail from DFM, here is the description :
EVENT DESCRIPTION = 192.168.5.200: Cisco Configuration Management Trap:InformAlarm; IF-192.168.5.200/53 [VL5] [192.168.5.200]:OperationallyDown;
Could you explain me this description please?
11-28-2006 07:27 AM
Hi Mathieu,
here is the DFM related Document for the descriptions:
OperationallyDown
Description: Interface?Card or network adapter's operational state is not normal. System Hardware?Disk's operational state is not normal.
Trigger: Polling, or processed trap (see Processed SNMP Traps).
Note For interfaces, DFM will only generate an OperationallyDown clear event if the card is reinserted into the same slot, and if the module index is the same before and after the card is reinserted.
Severity: Critical.
Device Type: All.
Event Code: 1018.
The difference is between the administratively up (you or another network engineer set the port down) and operational down (the interface is up but the line ist down).
Lets say you have set a port "no shut" on the command line the port is administratively up. If no cable is inserted in the port and the line is down the port is operational down.
Hope that helps a bit.
Best regards,
Frank
11-29-2006 04:30 PM
Event Description is as follows:
EVENT DESCRIPTION = 192.168.5.200: > this is the source of the event
Cisco Configuration Management Trap:InformAlarm >Event was triggered by an Cisco Config Mgmt Trap
IF-192.168.5.200/53 [VL5] [192.168.5.200] > first part ( IF-192.168.5.200/53) is the managed Object in DFM: an Interface of 192.168.5.200 with ifindex 53, interfaceType is Vlan 5 and has IP address 192.168.5.200
OperationallyDown > the interface is operationally down
02-15-2007 04:38 AM
There have been multiple events that have occured on the device.
One Event is a Cisco Configuration Trap which is classified as Inform alarm in DFM
Second event is Operationally down event of an Interface.
So the alert information of the device will have all the events inside the alert.
Radhika
