DFM.log ISSUE
I'm running Ciscoworks LMS 2.6 on win2k3 server.
Recently C:\ is running out of space, and investigating on this I've found a big DFM.log.030 (about 5 GB) in folder C:\Program Files\CSCOpx\objects\smarts\local\logs.
Logrot or Logbackup didn't help to reduce the file. I've tried to reboot the server but nothing happens.
DFM version is 2.0.10.
Could anyone suggest how to reduce the file? Can I just simply delete it?
Thanks for your support.
Ciao,
Massimiliano.
AFROJ AHMAD
Hi ,
Logrot should work  if not then  Yes you can simply Truncate the log fie :
Go to : NMSROOT\CSCOpx\log>logrot_trunc
e.g :c:\program files\CSCOpx\log>logrot_trunc DFM.log.030
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks--
Afroj
Thank you for the quick answer.
Running logrot_trunc command worked fine.
Redards,
Massimiliano.
