I have newly installed LMS 3.2.But device status in DFM shows "learning" state and 10% completed.Here attaching the screen shot
DFM 3.2.0
common services 3.3.0
RME 4.3.0
LMS is running on Windows platform.I am not using any .Net2.0 SP 1 update.
Restarted the DFM services and rebooted the server still no result.I have got the following procedure to be done if the device stuck up at 10%
Step 1 Download the tools from the following location: http://www.sysinternals.com/Utilities/PsTools.html
Step 2 Unzip it into a directory.
Step 3 Enter pdshow DfmServer pdshow DfmBroker to check whether the processes DfmServer and DfmBroker are running.
Step 4 Enter /objects/smarts/bin/brcontrol
Step 5 Check whether the host name is the same as in DNS.
Step 6 Check whether there are multiple instances of brstart and sm_server
You can use the downloaded Pstool to see one branch each of brstart and sm_serve.
For example:
pslist -t
brstart 5708 8 1 16 8476 1104 264
brstart 5880 8 7 86 32720 11240 9664
sm_authority 6452 8 1 52 14376 3616 1528
sm_server 6332 8 1 16 8476 1104 264
sm_server 6416 8 124 678 212696 58784 56812
sm_authority 6444 8 1 47 14376 3572 1528
There should be only one branch. You need to terminate any extra branches.
Step 7 Stop the daemon manager by entering net stop crmdmgtd.
Wait for five minutes.
Step 8 Enter netstat -a -n -p tcp to make sure that ports 9002 and 43501 to 43508 are not in listening state or timed wait state.
Step 9 Start the daemon managerby entering net start crmdmgtd.
Can any any body elaborate step number 3,5,6 and 8. will there be any impact if i go ahead with this procedure.
Ikbal
