Running last release of DFM in LMS 2.6 I have set utilisation alerts via DFM>Configuration>Polling and Thresholds>Managing thresholds to 70% for trunk links. However overnight when backups are running I am getting a fair amount of alerts which should be treated as "business as usual". Is there any way to switch off the alerting overnight or set core alerting periods between 08:00 -18:00?
Unfortunately, creating outage windows in DFM is not supported. You would have to manually unmanage the trunk ports during your planned maintenance windows, then remanage them when the window ends.
