DHCP RV340 does not deliver IP. dnsmasq-dhcp: Ignoring domain
rsanchezmartin
Beginner
Beginner
Hi all,
I have a Meraki AP connected in bridge mode (transparent) to a RV340 router. The AP has an SSID that is validated by domain in a windows radius server.
The issue is that when a windows client (e.g. windows laptop) tries to connect through the SSID Radius and it is authorized, the device does not obtain an IP from the DHCP server of the RV340 router.
I have checked connectivity problems and everything seems to be fine, I can reach to the radius server and I can confirm that radius server authorizes the connection but the device does´nt get IP from DHCP Cisco router.
I have also checked the logs of the RV340 and the AP please see below:
Log AP Meraki:
Client h4:9a:89:11:18:1e had a failed connection to SSID "mywifi" because the DHCP server did not respond.
Log RV340:
2023-06-06T14:48:22+00:00 <warning>dnsmasq-dhcp: Ignoring domain "mydomain.com" for DHCP host name "myhostnamedevice".
Thanks in advance everyone.
0 Replies 0
