DHCP with OPTION 230
Hello Team!
I have to send an option 230 named portal-addr with a url. is this configuration correct?
ip dhcp pool Client
network 192.168.0.0 255.255.240.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
option 230 ascii 'URL'
option 230 ascii URL
option 230 ascii "'URL'"
option 230 ascii "URL"
which one is correct?
NONE WORKS
is there something else missing?
in linux it is very simple, but I can't find it here
in mikrotik this is config:
/ip dhcp-server option
add code=230 name=portal-addr value=\
"'http://url.url'"
/ip dhcp-server option sets
add name=portal-addr options=portal-addr
/ip dhcp-server
add address-pool=dhcp_pool2 dhcp-option-set=portal-addr disabled=no \
interface=DHCP-IPTV name=dhcp1
in linux
cat /etc/dhcpc/dhcpcd-eth0.info
IPADDR=9.9.9.188
NETMASK=255.255.255.0
BROADCAST=9.9.9.255
DNS=9.9.9.228
INTERFACE='eth0'
PORTALADDR=url-url-url
thank you
0 Replies 0
