DHCP
Tahree
If I had a router that's connects my 2 LANs and there is a single DHCP, in the either LAN. How and what would be my configurations for the DHCP so that it provides the IPs to both the LANS through the router.
Thank you.
johnd2310
Level 8
Level 8
You will need to configure the scopes for the 2 lans on the dhcp server and configure ip helper on the interface facing the lan without the dhcp server e.g.
if the dhcp server is on gi0/2 and address 192.168.2.10, your router config may look as follows:
interface gi0/1
ip helper-address 192.168.2.10
interface gi0/2
ip address 192.168.2.1 255.255.255.0
clients on the same lan as the dhcp server do not need the helper address
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
interface gi0/1
interface gi0/2
John
