Highlighted
Digital Optical Monitoring Transceiver SNMP monitoring C7206VXR NPE-G2
We have C7206VXR NPE-G2 platform with transceiver which support DOM.
Could we monitor DOM tx/rx level statistic through snmp for 7206 platform?
In CLI result of command "sh interf GigabitEthernet0/1 transceiver" give some information.
We tried search for some MIB In "MIB locator" on cisco.com.
The MIB CISCO-ENTITY-SENSOR-MIB is supported for:
Release: 12.2(33) SRE3
Platform: 7200-NPE-G2
Featur Set: SP Services
But there is no result on SNMP for these OIDs.
2 REPLIES 2
Highlighted
Hall of Fame Guru
I believe the parameters you want should be available by using the CISCO-OPTICAL-MONITOR-MIB.
Highlighted
Thanks for response,
Unfortunaly parameters in tree 1.3.6.1.4.1.9.9.264 (CISCO-OPTICAL-MONITOR-MIB) did not available.
Content for Community-Ad
