02-26-2021 01:15 AM
Hi there,
We're switching to Ubiquiti UniFi AP's and therefore we need to disable the current WiFi Network on our Cisco 881-W.
I'm able to SSH into the router and login as admin, but I can't figure out how to disable the wifi network.
Can anyone help?
Solved! Go to Solution.
02-26-2021 02:46 AM
been long time worked on this, try below loging to module and shutdown the radio :
follow below guide : (let me know is that works ?)
https://www.networkstraining.com/cisco-router-wifi-wireless-configuration-881w/
02-26-2021 02:41 AM
Try
interface Dot11Radio0
shutdown
02-26-2021 02:46 AM
03-08-2021 05:37 AM
Hi This is what I did and it worked:
service-module wlan-ap 0 session
u: cisco pswd: cisco
interface dot11Radio0
Shutdown
