I'm using 5915's for embedded systems that boot, run for a while, and then turn off again. Configuration management is important to us. I'm getting messages at boot that PnP stopped because it detected a configuration file. Is there a way to disable that check/shut down PnP completely?
We don't want PnP to run even if there is no startup config present.
Here's the message that gets logged immediately after boot:
%PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
