FREDRIK SKUR
Beginner
Discovery exclude filter in LMS 4.0 not working?
On a fresh installed LMS 4.0 (Win2008 Std 64-bit) the discovery exclude filter seems not to work as expected
Global seed device configured is 172.30.50.10
ip address exclude filter is set to
172.16.125.*
172.17.125.*
172.18.125.*
172.20.125.*
172.22.125.*
172.24.125.*
Yet, the discovery job stops
ngdiscovery.log logs
[Oct 19  14:06:34] DEBUG  [ModuleWorker : EvalTask-DiscoveryThreadPool-01 applyAllModules]  : |172.30.50.10|Module System has been marked not to be proceessed further, reason is: Device: /172.30.50.10 is filtered by IP Address filter.
The discovery job creates CSdiscovery-config.xml, contains:
IPFilter Enabled="true">
            <IPIncluded/>
            <IPExcluded>
                <IPRange IPAddress="172.16.125.*"/>
                <IPRange IPAddress="172.17.125.*"/>
                <IPRange IPAddress="172.18.125.*"/>
                <IPRange IPAddress="172.20.125.*"/>
                <IPRange IPAddress="172.22.125.*"/>
                <IPRange IPAddress="172.24.125.*"/>
            </IPExcluded>
        </IPFilter>
2 REPLIES 2
Joe Clarke
Hall of Fame Cisco Employee
The exclude filter works on all IPs on a device.  If 172.30.50.10 contains any interface that contains an excluded IP, then that device will be excluded.  It looks like this might be the case here.
Yes, this is the case
Checked the environment, this is a single router network so the seed device does have an interface address matching the exclude filter
I will exclude that address from the exclude filter
Fredrik
