Discovery on Prime Infrastucture 2.2
mmacdonald70
I am trying to set up PI for the first time after upgrading from LMS.  I have run a discovery on the network and I'm having trouble with some unreachable devices.  There are two issues:
1.  I would like to be able to export the unreachable devices so that I can work on fixing the issues one at a time.  Is this possible
2. Some of the devices were discovered via CDP and identified themselves with an IP address that isn't on the network.  In LMS I was able to see CDP neighbors of all the discovered devices so I could locate these devices but I can't find out how to do this in PI
AFROJ AHMAD
Hi ,
1. exporting the unreachable devices , doesn't seems to be an option :(
2.you can use the topology map option to know the neighbor connecting to your devices , I think that will help
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
