Beginner
Re: DNAC PnP Day 0 Switch Provision with Template
Good command to know.
After:
*Feb 13 18:14:26.831: AUTOINSTALL: Setting hostname Switch.org.network from DHCP reply
*Feb 13 18:14:28.835: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server http://172.16.0.2:80/pnp/HELLO
*Feb 13 18:14:28.835:  port is 80
*Feb 13 18:14:30.840: %PNP-6-HTTP_CONNECTED: PnP Discovery connected to PnP server http://172.16.0.2:80/pnp/HELLO
this is what is seen looping around:
*Feb 13 18:14:58.842: %PNPA-DISCOVERY: PNP-CONFIG (6.0): failed to config [pnp profile pnp-zero-touch
transport http ipv4 172.16.0.2 port 80 vrf Mgmt-vrf
end
*Feb 13 18:14:58.842: %PNPA-DIAG: PNP-CONFIG (6.0): failed to config [pnp profile pnp-zero-touch
end
*Feb 13 18:14:59.843: %PNPA-DISCOVERY: PNP-CONFIG (6.1): failed to config [pnp profile pnp-zero-touch
end
*Feb 13 18:14:59.843: %PNPA-DIAG: PNP-CONFIG (6.1): failed to config [pnp profile pnp-zero-touch
end
*Feb 13 18:15:00.843: %PNPA-DISCOVERY: 1 _pddd.eRr.ccu: PnP profile config unsuccessful, retrying in 5s.Config count = 5
I've tried to research those errors but can't find anything substantial.
Are you using the management interface for PnP?
Beginner
Correct - using the Mgmt interface on the C4910R
i thought mgmt port was supported on all 9k.
that seems to indicate an issue with mgmt port.
can you just try an ethernet port as a test (just to rule out mgmt port causing issues)
Beginner
Thank you for your continued help with this Adam - really want to see this working now!
We tried the uplink from one of the SUP modules, and an ethernet port on one of the Line Cards.
Unfortunately, I have to report that this was unsuccessful in that the device just sat at:
Would you like to enter the initial configuration dialog? [yes/no]:
So we only seem to get any PnP traffic when using the Mgmt port...
Content for Community-Ad
July's Community Spotlight Awards
