DNS used with DHCP for Local Nodes
GCloutier167
I have a specific lab that uses a DNS & DHCP server.
On the DNS server, i have entered a few websites & a few computer IP address (PC0 = 192.168.0.10, PC1 = 192.168.0.20, etc.).
Fairly straight forward when IP address are static. When using a DHCP for dynamic addresses, how do i configure my DNS (PC0 = Variable address from DHCP server??).
Thank's for any input on this "simple" question that's giving me trouble.
2 Accepted Solutions
DDNS does not work in or with PT;
PT is just a sim to simulate real IOS; it is not real IOS, not all features are included and those that are may or may not behave as real IOS or device (Cisco and not)
Regards, ML
**Please Rate All Helpful Responses **
6 Replies 6
Martin L
If you use DHCP server with pools to give away IPs, there is a setting for DNS and default gateway. Drag server icon and look under service tab GUI .  There are some examples in every PT install. look for File > open samples and find dhcp example
if you use a router as DHCP server, configure a pool for LAN with following dns service
ip dhcp pool MARTIN
network 10.1.0.0 255.255.255.0
default-router 10.1.1.1
dns-server 8.8.8.8
You can attach your PT file here (must be in a zip format).
Regards, ML
Hello Martin & thank's for your feedback. I have included my "simple" network.
From PC1, i'm trying to ping PC0. I think my config is good, but in the DNS server, i have to enter PC0's address. Which is easy when using static addresses. If using DHCP, i am not certain how to associate in the DNS a node to a variable address.
Thank you so much!! That's exactly it
You are so so welcome
Regards, ML
