06-18-2022 02:02 AM
Hi all,
I've working with NXOS for a while, mostly nexus 3000s, and today I have an issue with role"network-operator".
Basically, an user belong to network-operator can not "show running-config or startup-config" but what if network-operator could copy running-config to other location to view ? Is it possible ?
06-18-2022 02:24 AM
- I would presume not , do you have possibility to test ?
M.
06-18-2022 05:23 AM
Thank for your response.
I've tried and the closest thing was "copy license" command.
However, when I set community string group network-operator, somehow the network OpManager could show the running config.
So I wonder, is it a vulnerability of NXOS or my mistake when set up snmp ?
part of configure
snmp-server community r4&TkX54TUSFh ro
snmp-server community r4&TkX54TUSFh use-ipv4acl Limmit-SNMP
06-18-2022 09:14 AM
- You may verify this with the command : show cli syntax roles network-operator
M.
