Double Natting Cisco 800 series router and Cisco asa 5505
a.liwag
Hello guys,
Did anyone configure a network with the same set up on the image below. I want to NAT all my public ip to all my servers at 10.64.51.0 network ( LAN) I want to do static nat. Currently i tried to do a nat in the VPN router e.g. ip nat inside source static 200.2.2.55 94.11.212.194. And in the ASA i create also a nat that will translate 200.2.2.55 to 10.64.51.55 which is one of our server that we want to access outside. Unfortunately is not working. I need some advice. Thank you so much!.
0 Replies 0
