04-26-2014 08:12 PM
Is there a way to use event manager to replace tunnel destination ip each time it changes ?
1. Resolve the hostname
2. Set it as a variable
3. Use the variable to replace the IP
int tunnel 0
tunnel destination <a>
Mostly like a reverse dynamic dns.
Solved! Go to Solution.
04-26-2014 10:58 PM
What about this:
event manager environment saved_ip 0.0.0.0
event manager applet change-tunnel
event timer watchdog time 60
action 001 cli command "enable"
action 002 cli command "ping ip hostname repeat 1"
action 003 regexp "Echos to ([0-9\.]+)" $_cli_result match ip
action 004 if $ip ne $saved_ip
action 005 cli command "config t"
action 006 cli command "int tun0"
action 007 cli command "tunnel destination $ip"
action 008 cli command "event manager environment saved_ip $ip"
action 009 cli command "end"
action 010 end
05-03-2014 11:20 PM
Ah, I get the logic now.
In that case, insert the following actions and push everything else down.
action 008 regexp "!!" $_cli_result
action 009 if $_regexp_result eq 1
action 010 exit 0
action 011 end
04-26-2014 10:58 PM
What about this:
action 010 end
04-27-2014 10:01 AM
YOU ARE A GENIUS! It works perfectly.
I have been looking for a solution to this problem for quite a while now.
Could we make each 45 seconds
>ping ip 10.255.255.1 repeat 2
If "!" stop
If ".." run the script below ?
here's what i'm using and it really works!
action 002 cli command "config t"
action 003 cli command "int tunnel 40"
action 004 cli command "no ip nhrp map multicast $ip"
action 005 cli command "end"
action 006 cli command "ping ip rtr1.noip.me repeat 1"
action 007 regexp "Echos to ([0-9\.]+)" "$_cli_result" match ip
action 008 if $ip ne $saved_ip
action 009 cli command "config t"
action 010 cli command "int tunnel 40"
action 011 cli command "ip nhrp map multicast $ip"
action 012 cli command "ip nhrp map 10.255.255.1 $ip"
action 013 cli command "event manager environment saved_ip $ip"
action 014 cli command "end"
action 015 end
end
04-27-2014 02:15 PM
To go to 45 seconds, just change the 60 second watchdog timer to 45. As for the ping test, why would you want to update the tunnel if the ping fails? I would think you'd want the opposite.
05-03-2014 04:33 PM
Sorry for the Late response.
The goal of updating the tunnel is to update it only when the ping fails.
From a dmvpn spoke perspective, if I can't reach my hub anymore, it means that the Hub changed of IP.
There is no need to re-update the Hub address as it's not changing. We only want to update it if it changes.
Does that makes more sens ?
05-03-2014 11:20 PM
action 010 exit 0
action 011 end
