Dynamic Vlan based on subnet?
maximeg0189
Frequent Visitor
Frequent Visitor
Hello all,
I am wondering, at my current workplace we have 70 switches + 2 big core. We have over 50 vlans.
one of the main annoying thing is the printers. Since printers need to have a static IP we created a vlan for printers. But everytime a user change the port move a printer or anything the printer stops working because it is not in the right vlan.
I was wondering if there was a way to like either allow a vlan on another vlan or be able to change the port automatically based on the unique subnet of the device connected?
or any solutions we do get atleast 2-3 calls a week to change the vlan on port.
Or any other solution ?
balaji.bandi
You can do with identity-based authentication if you have in a place like ISE / or any Freeradius.
Another way I can think of EEM Script sitting in each switch or out-of-the-box script. (if you know the MAC Address of the vendors, then if you find it in that port shut down the port and change the VLAN ( Hope your printer are DHCP based and they get Static Address from the DHCP for thatMAC Address?)
is this make sense?
BB
maximeg0189
Frequent Visitor
Frequent Visitor
@balaji.bandi
To give you more context I work in a factory. Its a giant site with a lot of trailers. They change the configuration after each projet. I am losing so much time every week trying to put all the right vlan.
But we do have more than 253 computers. We have more than 1 vlan for computers.
what I was wondering is that can I name the printer vlan and other vlan like that:
Vlan 6-7-8-9 = Desktop
Vlan 50 = Printers
And put a rule like  Mac address from HP, canon goes into printers vlan
lenovo = desktops vlan
that way it would take the vlan of the site based on the name
im not sure If I make sense. I will def google to learn more about Radius based on MAC address
balaji.bandi
Vlan 50 = Printers
you can do that - if the one doing patching to switch
take an example in the switch 1-35 port for Data VLAN for 6-9 VLAN   35-48 for VLAN 50 ( assuming you have 48 port switch)
HP, canon  - these vendors have predefined the first half MAC Address same, so you can run the EEM Script on with as suggested.
You can take advantage of this EEM - mat MAC address table event
you can try below: on 1 switch  (make you understand the EEM script - before you doing in Live environment)
event manager applet PRINTER
event mat interface regexp GigabitEthernet.* type add
action 001 regexp "XXXX.YY" $_mat_mac_address                           <-------- change the mac address from vendor
action 002 if $_regexp_result eq 1
action 003 cli command "enable"
action 004 cli command "config t"
action 005 cli command "interface $_mat_intf_name"
action 006 cli command "shutdown"
action 006 cli command "switchport access vlan 50"
action 007 cli command "no shutdown"
action 008 cli command "end"
action 009 end
BB
