[EARLY TRIAL] Meraki-native onboard & monitoring: Catalyst 9K Switches
CM CAT EPM
Let's get ready to rumble!!!
We're thrilled to announce an exciting opportunity for you to join our Early Field Trial for Cloud Monitoring of Catalyst Switches (very soon to include Cloud CLI). With the release of IOS XE 17.15.1, we're transitioning to Meraki-native onboarding, integrated seamlessly with the Meraki dashboard.
Why Join the Trial?
  • Effortless Integration: Experience the powerful combination of Cloud-Native IOS XE with the intuitive Meraki Dashboard.
  • Enhanced Network Operations: Enjoy seamless onboarding, along with live data and
  • comprehensive performance and health indicators for your Catalyst switches.
  • Supported Models: Participate with C9200, C9300, and C9500 series switches and switch stacks.
To be part of this groundbreaking trial in early January-February 2025, please express your interest using the link below. Make sure to include your organization details as requested. Once we process your application, you'll hear from us via Stomio to kick off your trial experience.
Join us in this journey to simplify and elevate your network operations with the best of Catalyst and Meraki!
Important: Confirmation of trial participation will come from Meraki via Stomio. Onboarding in dashboard ahead of this will default Catalyst switches to Cloud managed mode, which alters the switch configuration and will require manual correction.
Link to sign up: https://docs.google.com/forms/d/e/1FAIpQLSfx3hwfEdnTSX9hdA0iHiJ7jBeU1oiT7EySjOUvQt-boFxyKg/viewform
grpalmer2
Level 4
Level 4
Hello @CM CAT EPM. The QR code is not active. Are you able to share the link with me?
CM CAT EPM
@grpage thanks for reporting this - we are review it now and will circle back.
