EEM - Applet Help Appreciated
I am using the following applet to modify entries in two ACLs from a mobile device. Please see applet below with output from a test run:
3    applet    user    none                Off   Sun Mar 28 22:42:59 2010  rite1
policyname {rite1} sync {yes}
maxrun 60.000
action 1.0 puts "Set HostA:"
action 1.1 gets hosta
action 1.2 puts "Set HostB:"
action 1.3 gets hostb
action 1.4 cli command "enable"
action 1.5 cli command "config t"
action 1.6 cli command "ip access-list extended rite1_incoming"
action 1.7 cli command "no 10"
action 1.8 cli command "no 20"
action 1.9 cli command "10 permit ip host $hosta host $hostb"
action 2.0 cli command "20 permit ip host $hostb host $hosta"
action 2.1 cli command "ip access-list extended rite1_outgoing"
action 2.2 cli command "no 10"
action 2.3 cli command "no 20"
action 2.4 cli command "10 permit ip host $hosta host $hostb"
action 2.5 cli command "20 permit ip host $hostb host $hosta"
action 2.6 cli command "end"
action 2.7 cli command "show ip access-list | s rite1"
action 2.8 puts "$_cli_result"
action 2.9 puts ""
action 3.1 puts "-------------------------------------"
action 3.2 puts ""
action 3.3 puts "Use following packet_capture commands:"
action 3.4 puts " ritesh - show packet_capture"
action 3.5 puts " ritecl - clear packet_capture"
action 3.6 puts " ritestr - start packet_capture"
action 3.7 puts " ritestp - stop packet_capture"
action 3.8 puts ""
action 3.9 puts "-------------------------------------"
alias exec rite1 event manager run rite1
Router#rite1
Set HostA:
172.20.1.1
Set HostB:
20.1.1.1
Extended IP access list rite1_incoming
    10 permit ip host 172.20.1.1 host 20.1.1.1
    20 permit ip host 20.1.1.1 host 172.20.1.1
Extended IP access list rite1_outgoing
I use this for packet capturing with RITE on remote sites that do not warrant consistent samples. We get alerted when a specific top-talker is showing unusual high volumes of traffic and our techs are able to run the following script on the fly from mobile devices. The high-volume converstaion gets captured and we have another script that exports those onboard captures to centralized servers. The whole operation runs pretty great. The problem is that for some reason it eats a TON of process usage.
117852: Mar 28 23:03:54.197 DST: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr): 72%/1%, Top 3 processes(Pid/Util):  199/71%, 49/0%, 81/0%
117865: Mar 28 23:04:09.128 DST: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr) 1%/0%.
I"m assuming that process # 199 is dynamically created for this specific applet when it runs, as it does not seem to run on the routers at other times:
Router#show process cpu
....output omitted....
198           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
201       14371       99291        144  0.00%  0.00%  0.00%   0 DHCPD Receive
For some reason, while the router is interacting with the user, waiting for input from the "action x.x get" commands, the processer is through the roof. Any ideas on how I could run this similar operation without taking up so much process overhead? I want to say that I could probably limit the resource usage of those specific processes maybe with ERM, but I'm currently not very familiar with ERM. Thanks for everyone's help.
7 Replies 7
yjdabear
Collaborator
Collaborator
I'm afraid you may have to convert the applet to a tcl script, in order to gain some form of resource control, specifically via the "nice #" option, which appears to be in the same boat as "queue_priority" discussed in this Q&A: https://supportforums.cisco.com/message/3030779#3030779
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
There appears to be a bug in the gets action which causes a CPU spike.  This does not happen if you use Tcl, though.  I converted your applet to a Tcl policy.  You should be able to see more reasonable gets behavior.
Joe,
This works great. Thanks again for all of your help.
Joe,
Thanks so much for converting our applet into a tcl script. It works great everywhere that we have deployed it. We did run into one issue deploying on a 3745 Router with 12.4(15)T9. When the policy was triggered, we received the following error:
error reading "stdin": Unknown error 134217728
    while executing
"gets stdin"
    invoked from within
"$slave eval $Contents"
    (procedure "eval_script" line 7)
    invoked from within
"eval_script slave $scriptname"
    invoked from within
"if {$security_level == 1} {       #untrusted script
     interp create -safe slave
     interp share {} stdin slave
     interp share {} stdout slave
    (file "tmpsys:/lib/tcl/base.tcl" line 50)
Tcl policy execute failed: error reading "stdin": Unknown error 134217728
I also pulled the specific script that it's referencing the error from:
# base.tcl - Safe base script forinvoking safe-tcl on FM policies.
# August 2002, Jason Pfeifer
# Copyright (c) 2002, 2004-2006 bycisco Systems, Inc.
# All rights reserved.
# Current security levels:
# 0 - trusted script, safe mode not enabled
# 1 - untrusted script, safe modeenabled
####################   Procedures  ##################
proc TraceVariable { fromInterp fromVartoInterp toVar } {
    set value [ interp eval $fromInterpset ::$fromVar]
    interp eval $toInterp [list set::$toVar $value]
proc eval_script { slave scriptname } {
    # Open script and evaluate it in slave
    set F [open $scriptname]
    set Contents [read $F]
    close $F
####################  End of Procedures  ##################
# main
# Process argv input:
set scriptname [lindex $argv 0]
set security_level [lindex $argv 1]
if {$security_level != 0 && $security_level != 1} {
    set security_level 1
#Set Security level specific parameters
set errorInfo ""
set FM_TCLLIBDIR [info library]
     interp share {} stderr slave
     lappend global_vars auto_path
     lappend global_vars auto_oldpath
     lappend global_vars tcl_library
     foreach entry [info vars] {
         if [array exists $entry] {
             continue
         if {[lsearch -exact$global_vars $entry] >= 0} {
             continue;
         TraceVariable {} $entry slave$entry
     # uncomment to debug safe.tcl
     #::safe::setLogCmd puts stderr
     ::safe::interpInit slave
     # Hidden commands that are exposed to slave to ease restrictions.
     interp alias slave exit {} exit
     interp expose slave fconfigure
     interp expose slave socket
     close stdin
     close stdout
     close stderr
     ::safe::interpDelete slave
} else {                          #trusted script
     interp create slave
             continue
     if {[catch {::interp eval slave\
             {source [file join$FM_TCLLIBDIR init.tcl]}} msg]} {
         error "can't sourceinit.tcl into slave ($msg)"
     interp delete slave
What ended up happening is the script stayed stuck in pending(no 'scheduler' commands in this early version of eem) and we eventually had to reboot the router(we waited until a regularly scheduled maintenance window, so it worked out fine). Since receiving this error, we haven't tried to run this particular script on this particular router. All other devices that we have deployed this on, including other 3745's running 12.4(15)T, have worked great. If anyone has some idea as to exactly what happened and what adjustments we need to perform to correct the problem, we would greatly appreciate it.
Thanks again for everyone's help.
Joe Clarke
There is typically some other error related to this (e.g. Process forced exit).  I have a 3745 running 12.4(15)T12, and it works just fine.  I will say that there were quite a few EEM bugs fixed around this version, and if possible, an upgrade might be helpful.  Yes, if a script gets stuck in EEM prior to 2.4 (and 12.4(15)T has 2.3), then a reload will be required to free the queue.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Joe,
Thanks for such a quick response. I did upgrade this device to 12.4(15)T13 today, and we have had the script in question running on a few other 3745's without issue. Aside from CPU-hog protection, are there any other preventions that we can take when running a fair amount of scripts on a device that cannot upgrade past 12.4(15)T?
Joe Clarke
You can increase the number of script threads assigned to the default scheduler class as a way to accommodate multiple parallel scripts (and potentially work around stuck threads).  However, the only way to clear such a thread will be with a reload.  To increase the number of threads, configure:
event manager scheduler script thread class default number X
Where X is a number between 1 (the default) and 65535.
Recognize Your Peers
