EEM for Dual SIM - SNMP OID failed, is there another way?
rkalaivanan
Hi all,
I'm trying to configure a dual SIM toggle solution for Cisco 819 router and been struggling for 2 weeks now. The example available online using SNMP OID '1.3.6.1.4.1.9.9.661.1.3.2.1.18.12' is not working for me. I get a "NO_SUCH_INSTANCE_EXCEPTION".  Using config below :
event manager applet DualSIM
event timer watchdog time 3600
action 1.0 info type snmp oid 1.3.6.1.4.1.9.9.661.1.3.2.1.18.12 get-type exact
action 1.1 syslog msg "Carrier is $_info_snmp_value"
Next i tried to manually get the carrier name from "sh cellular 0 network" command and assign it to a variable and use If/else logic to compare with string i specify but this fails too, i dont get a match and it always goes to 'else'.
Any idea what am i doing wrong here please?
Configuration :
event manager applet SIM
event tag e1 track 10 state down
event tag e2 timer countdown time 120
trigger
correlate event e1 or event e2
action 1.0 track read 10
action 1.1 if $_track_state eq "down"
action 1.15 cli command "enable"
action 1.2 cli command "sh cellular 0 network | inc Network ="
action 1.4 string trimleft "$_cli_result" "Network = "
action 1.5 syslog msg "$_string_result"
action 1.6 if $_string_result eq "CELCOM"
action 1.7 syslog msg "CELCOM Network Issue. Switching to DIGI"
action 1.8 cli command "clear interface cellular 0"
action 1.9 cli command "cellular 0 lte sim activate slot 0"
action 2.0 else
action 2.1 syslog msg "Digi Network Issue. Switching to CELCOM"
action 2.2 cli command "clear interface cellular 0"
action 2.3 cli command "cellular 0 lte sim activate slot 1"
action 2.4 end
action 2.5 end
Hey Joe,
Thanks for your reply, i managed to get it working.
For the benefit for other folks looking for solution, here's the EEM script I'm using :
 trigger
 action 1.2  info type snmp oid 1.3.6.1.4.1.9.9.661.1.3.2.1.9.14 get-type exact
 action 1.3  syslog msg "Carrier is $_info_snmp_value"
 action 1.4  set x "$_info_snmp_value"
 action 1.5  cli command "enable"
 action 1.6  if $x eq "CELCOM"
 action 1.9   cli command "cellular 0 lte sim activate slot 1"
 action 2.0  else
 action 2.3   cli command "cellular 0 lte sim activate slot 0"
 action 2.4  end
 action 2.5 end
Joe Clarke
I'd either need to see the full output of "show cellular 0 network" or a walk of 1.3.6.1.4.1.9.9.661.1.3.2.1 to know what advice to give you.
Hey Joe,
 trigger
 action 2.0  else
 action 2.4  end
 action 2.5 end
