ā02-08-2017 06:52 AM
Is there a way to make a EEM script to shutdown E1 interface when SyncE QL goes under SSU-A?
I don't what to match sh log output
ā02-12-2017 04:46 AM
Please provide the step-by-step instructions on how you would do this manually. If it can be done manually through SNMP or CLI, then it should be doable with EEM.
ā02-13-2017 01:28 AM
Thank you for your replay, this would really help me
1. If a QL announcement arrives from the network, like "%NETCLK-6-QL_CHANGE:" or if the router looses the communication to all clocks in the network and starts to use the internal clock "%NETCLK-6-ENTER_HOLDOVER:" then...
2. Wait for about 5 minutes.
3. Then If the output from "show network-clocks synchronization" shows either QL-PRC or QL-SSU-A, then bring up 8 interfaces. But if the output show neither of QL-PRC or SSU-A then shutdown 8 interfaces and save configuration.
4. Run step 3 every 30 minutes
ā02-13-2017 01:56 AM
This is not enough information. What does the output of "show network-clocks synchronization" look like when it's healthy? When it's not? On what platform is this? What version of software?
ā02-13-2017 02:17 AM
This is the output, it's a ASR 920 IOS XE 3.18.1s
In this output I have QL-PRC from both interfaces.
If the show command doesn't show either QL-PRC or QL-SSU-A anyware in the output, then shutdown 8 interfaces (controller e1 0/1/0 - 8)
router#sh network-clocks synchronization
Symbols: En - Enable, Dis - Disable, Adis - Admin Disable
NA - Not Applicable
* - Synchronization source selected
# - Synchronization source force selected
& - Synchronization source manually switched
Automatic selection process : Enable
Equipment Clock : 2048 (EEC-Option1)
Clock Mode : QL-Enable
ESMC : Enabled
SSM Option : 1
T0 : TenGigabitEthernet0/0/15
Hold-off (global) : 300 ms
Wait-to-restore (global) : 10 sec
Tsm Delay : 180 ms
Revertive : Yes
Nominated Interfaces
Interface SigType Mode/QL Prio QL_IN ESMC Tx ESMC Rx
Internal NA NA/Dis 251 QL-SEC NA NA
Te0/0/14 NA Sync/En 3 QL-PRC - -
*Te0/0/15 NA Sync/En 2 QL-PRC - -
ā02-15-2017 02:07 AM
And this is the output when the eem/tcl should shutdown the interfaces, in the output both PRC and SSU-A is missing
drwrdc1rout1d#sh network-clocks synchronization
NA - Not Applicable
ESMC : Enabled
SSM Option : 1
T0 : TenGigabitEthernet0/0/14
Tsm Delay : 180 ms
Revertive : Yes
*Te0/0/14 NA Sync/En 3 QL-SSU-B - -
ā02-27-2017 07:43 AM
I think this will work for you.
event manager environment q "
event manager environment cr $_cli_result
event manager environment rr $_regexp_result
event manager applet clock-sync
event syslog pattern "NETCLK-6-(QL_CHANGE|ENTER_HOLDOVER)"
action 001 cli command "enable"
action 002 cli command "config t"
action 003 cli command "event manager applet clock-sync-timer"
action 004 cli command "event timer countdown time 300"
action 005 cli command "action 001 cli command enable"
action 006 cli command "action 002 cli command $q show network-clocks synchronization | inc (QL-PRC|QL-SSU-A)$q"
action 007 cli command "action 003 regexp $q *(QL-PRC|QL-SSU-A)$q $cr"
action 008 cli command "action 004 if $rr eq 0"
action 009 cli command "action 005 cli command $q config t$q"
action 010 cli command "action 006 cli command $q int range Te0/0/1 - 8$q"
action 011 cli command "action 007 cli command $q shut$q"
action 012 cli command "action 008 else"
action 013 cli command "action 009 cli command $q config t$q"
action 014 cli command "action 010 cli command $q int range Te0/0/1 - 8$q"
action 015 cli command "action 011 cli command $q no shut$q"
action 016 cli command "action 012 end"
action 017 cli command "action 013 cli command $q no event manager applet clock-sync-timer$q"
action 018 cli command "action 014 cli command end"
action 019 cli command "action 015 cli command $q write mem$q"
action 020 cli command "end"
