10-08-2014 10:32 AM
Howdy all.
I'm hoping someone can help answer whether EEM is supported on a 2960S switch with LANBASE (not LAN Lite). I'm running 12.2(55)SE9 UNIVERSAL, which, according to Feature Navigator, supports EEM 3.2.
When I try to configure event manager on the CLI, the command is unrecognized.
I have tried this under both the default and lanbase-routing SDMs.
Justin
Solved! Go to Solution.
10-08-2014 10:55 AM
The 2960 only supports EEM-lite (to drive auto smart ports). You will not be able to configure your own EEM policies.
10-08-2014 10:55 AM
10-08-2014 02:54 PM
Good to know. Thanks Joe! I was hoping the EEM guru would chime in. :)
01-09-2017 06:57 AM
I am not able to configure EEM script on WS-C2960-24TC-L running c2960-lanbasek9-mz.150-2.SE7.bin.
Here is the error message.
IND-HYF-CON-ACC-SW-0(config)#event manager
% Invalid input detected at '^' marker.
IND-HYF-CON-ACC-SW-0(config)#e?
eap enable end energywise
epm errdisable exception exit
Not getting option for any command like event manager.
01-11-2017 01:14 AM
As already stated in this thread, EEM is not supported on the 2960 series. Only EEM-Lite is supported, and this means you cannot configure your own policies.
01-20-2019 06:10 AM
Hi Joe, how does eem lite differ from eem and where can i get more info about eem lite.
01-22-2019 09:09 AM
EEM Lite drives Auto Smartports. So there are internal hooks to react to CDP/LLDP neighbors, MAC address changes, and dot1x changes. There are no external/CLI facing interface for this other than the ASP commands.
09-05-2020 04:16 PM
Hi Joe,
I know the smart port feature. Can we by any means auto shut the ports if the alternate port is down.
Example:
if fa0/1 went down. Then fa0/2 shut be shut ( I have achieved this)
but if i bring up port fa0/1 then fa0/2 should also come up. (these is easily do able with eem , But not able to do it on 2960.)
