EEM on 3550 Switch
It looks like the 12.2(52) release is able to run EEM. This only seems to be currently available for the WS-3550-24-DC-SMI model but I have that image loaded on a WS-3550-PWR-EMI:
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 09:05 by sasyamal
Image text-base: 0x00003000, data-base: 0x015DB684
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 22 minutes
System image file is "flash:/c3550-ipservicesk9-mz.122-52.SE.bin"
...output omitted...
Cisco WS-C3550-24-PWR (PowerPC) processor (revision G0) with 65526K/8192K bytes of memory.
Running Layer2/3 Switching Image
Model number: WS-C3550-24PWR-EMI
Embedded Event Manager Version 3.20
Component Versions:
eem: (v320_throttle)2.1.50
eem-gold: (v320_throttle)1.0.4
eem-call-home: (v320_throttle)1.0.4
Event Detectors:
Name                  Version   Node        Type
application             01.00     node0/0     RP
neighbor-discovery  01.00     node0/0     RP
identity                  01.00     node0/0     RP
mat                       01.00     node0/0     RP
syslog                   01.00     node0/0     RP
routing                   03.00     node0/0     RP
cli                           01.00     node0/0     RP
counter                  01.00     node0/0     RP
interface                 01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                     01.00     node0/0     RP
oir                        01.00     node0/0     RP
snmp                    01.00     node0/0     RP
snmp-object          01.00     node0/0     RP
ipsla                     01.00     node0/0     RP
snmp-notification    01.00     node0/0     RP
timer                    01.00     node0/0     RP
rpc                       01.00     node0/0     RP
This is in a lab environment but it seems to be holding up fine. Does anyone know if they will release this image for the other 3550 models? Has anyone tested with this image yet, either on the 3550-24-DC-SMI model or any other model?
Thanks for your help.
6 Replies 6
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Essentially, all but the DC 3550s are end of life, so no new images are being released.  However, all 3550s run the same image.  In fact, I loaded 12.2(52)SE on my WS-C3550-24-SMI, and it works just fine.  I have been doing quite a bit of EEM work on this switch so I could build solutions using the new EDs.
This is excellent news. We have a large amount of 3550's installed, and we could use EEM at many of these locations. What would be the best source for documentation? I can see that the event detectors are somewhat different from those available in the ISRs. The "track" ED is gone but the "mat" and "neighbor-discovery" EDs look very interesting. Would the config guides for the 3560 switches be applicable?
Joe, thanks for all of your help.
EDIT: I found the eem version 3.2 release notes and config guides. Thanks.
Joe Clarke
Yes, the docs for the 3560 covering 12.2(52)SE or higher would be applicable when it comes to EEM.  The new EDs (mat and neighbor) allow you to monitor MAC address table changes and CDP/LLDP neighbor changes.  The desktop switches do not support enhanced object tracking, so the track ED is not there.  However, you do have EEM 3.2, so programmatic applet support is there as well as multi-event, EEM RPC, SNMP trap support, etc.
Will this version support to below mentioned command?12.2(52)SE
EVENT TRACK command under EEM
CORE(config)#event manager applet test
COREconfig-applet)#even
CORE(config-applet)#event ?
  application         Application specific event
  cli                 CLI event
  counter             Counter event
  identity            Identity event
  interface           Interface event
  ioswdsysmon         IOS WDSysMon event
  ipsla               IPSLA Event
  mat                 MAC address table event
  neighbor-discovery  Neighbor Discovery event
  none                Manually run policy event
  oir                 OIR event
  routing             Routing event
  rpc                 Remote Procedure Call event
  snmp                SNMP event
  snmp-notification   SNMP Notification Event
  snmp-object         SNMP object event
  syslog              Syslog event
  tag                 event tag identifier
  timer               Timer event
kumar
Joe Clarke
No, event track is not supported on this platform.  However, you could use the syslog ED to match on the syslog tracking message.
event syslog pattern "TRACKING-5-STATE.* 123 .* Up->Down"
Thanks, Now i am doing  with syslog tracking message..its working fine.
Kumar
