05-13-2013 11:57 PM
Hi all,
I'm new to EEM and we are investigating using it to solve some issues that we are having, However, I can't seem to find any definitive information which tells me whether EEM is available in the nexus 5548 switches. Can anyone here help to confirm if this is the case? If not yet avalable for the 5548s, are there any indications as to when it might become available?
thanks,
Ram
05-14-2013 08:22 AM
No, EEM is not yet available on the N5K. Last I was told it will be there in 7.0.
06-20-2013 01:13 PM
Might want to try the 6.0(2)N1(2) and later code. I have it loaded on a N6004 and EEM is available there. It is of course the NX-OS flavor of EEM but it is there.
N6K-Switch# show ver | grep 'System version'
System version: 6.0(2)N1(2)
N6K-Switch# conf t
Enter configuration commands, one per line. End with CNTL/Z.
N6K-Switch(config)# event manager ?
applet Create/Modify an Event Manager Policy
environment Configure an environment variable
policy Register a script policy and activate it
Mike
