EEM OSPF syslog
nvanhaute
hi all,
I'm using EEM to be warn by mail when my OSPF adj changes ; I use OSPF in tunel int, so I can know when tunnel is down/up.
My script works well but sometimes I do not receive any mail whereas adj changes, so I can receive mail with "up" whereas I did not receive "down".
I ask me if there is no rate-limiter on syslog msg that could explain my issue. what else ? if you have an idea, I'm interested.
Other problem in my case, when my Internet access falls down, I receive tons of mail (one by tunnel interface ; I have 50 int tunnel !)... so I would like to improve my script to detect internet issue and in that case send only a mail to tell me : no internet. Same when Internet is back.
my script :
event manager environment mail_smtp aaa.bbb.ccc.ddd.eee
event manager environment mail_to aaaa@aaa.aa
event manager applet OSPFtunnelDOWN
   event syslog pattern "OSPF-5-ADJCHG.*FULL to DOWN"
   action 100 info type routername
   action 110 regexp "on ([_0-9a-zA-Z]*) from" "$_syslog_msg" result nominterface
   action 120 cli command "show interface $nominterface"
   action 130 regexp "Description: ([a-zA-Z0-9\-]+)" "$_cli_result" result site
   action 200 mail server "$mail_smtp" to "$mail_to" from "$_info_routername@aaa.aa" subject "down : $site" body "down $site"
event manager applet OSPFtunnelUP
   event syslog pattern "OSPF-5-ADJCHG.*to FULL"
   action 200 mail server "$mail_smtp" to "$mail_to" from "$_info_routername@aaa.aa" subject "up : $site" body "up $site"
help is welcome
thanks
Niko
22 Replies 22
I think the thread option is best.  While you can increase the VTYs, you are also increasing the load on your device by running so many policy instances at once.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
ok I just tested in putting :
thread 8 and vty 10 => no success (still problem)
thread 8 and vty 15 => seems to be ok :-)
sounds ok for you now ?
Niko
You just need to make sure you have enough VTY lines free to satisfy all your policy instances, all of your interactive sessions, then one extra as EEM will not take the last free VTY line.  So if 15 is the magic number for you, that sounds good.  That is the default.
ok so if I need to add again tunnel interface, I have to check if I still have enough vty lines
so if not enough, I increase it (vty) until it is ok ?
thanks for your big help
NIko
No.  By keeping your threads at eight, you ensure that EEM will only ever need up to nine VTY lines to be free.  So you can add as many tunnels as you want provided you can keep nine lines free at any given time.
I should say that the particular EEM CLASS will only need up to nine VTY lines.  If you have other policies configured in other thread classes, you may still require more free VTY lines.
Hi Joseph,
I'm back to you because now I have more than 40 tunnel interfaces and I get this message in log :
%HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
remember you my configuration :
line vty 5 15
login
transport input none
event manager environment mail_smtp ****
event manager environment mail_to *****
event manager environment mail_from *****
event manager scheduler applet thread class default number 8
action 200 mail server "$mail_smtp" to "$mail_to" from "$mail_from" subject "$site UP" body "$site is up"
event syslog pattern "OSPF-5-ADJCHG.*FULL to *"
action 200 mail server "$mail_smtp" to "$mail_to" from "$mail_from" subject "$site DOWN" body "$site is down."
so what I need to change again to not get this error in log and get mail alert ? increase vty lines => 5 20 ?
best regards
Nicolas
PS : this issue is present only in eem version ? maybe with new IOS it's ok and I don't need more vty lines ?
For this configuration, you could need at least nine free VTY lines.  Upgrading IOS will not change that requirement.  If you only have "line vty 0 5" configured, you need to increase that to at least "vty 0 8".  If all eight threads execute, then you can only have one user logged in.  Any more that that, and you will see the error you're seeing.  You can also reduce the thread count some more to limit the number of concurrent policies.
