EEM script for high CPU
CORY HEBERT
Hi, all.  So I have a simple EEM script for my 4507 closet switches to poll every minute for high CPU (above 75%), and log it to bootflash:
event manager applet HIGH_CPU
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge entry-val "75" poll-interval 60
  action 10 syslog msg "High CPU detected.  Logging latest information to bootflash:high_cpu.txt"
  action 20 cli command "term exec prompt timestamp"
  action 30 cli command "show process cpu sorted | redirect bootflash:high_cpu.txt"
  action 40 cli command "y"
  action 50 cli command "term no exec prompt timestamp"
And I can see the applet being triggered:
SWITCH#sh event manager history events
No.  Job Id      Status   Time of Event             Event Type          Name
1    21          success  Sun Mar 2  00:40:23 2014  snmp                applet: HIGH_CPU
2    22          success  Sun Mar 2  02:01:24 2014  snmp                applet: HIGH_CPU
3    23          success  Mon Mar 3  00:31:35 2014  snmp                applet: HIGH_CPU
4    24          success  Mon Mar 3  02:01:36 2014  snmp                applet: HIGH_CPU
5    25          success  Tue Mar 4  00:30:47 2014  snmp                applet: HIGH_CPU
6    26          success  Tue Mar 4  02:00:48 2014  snmp                applet: HIGH_CPU
7    27          success  Tue Mar 4  02:01:48 2014  snmp                applet: HIGH_CPU
8    28          success  Wed Mar 5  00:31:00 2014  snmp                applet: HIGH_CPU
9    29          success  Wed Mar 5  02:01:00 2014  snmp                applet: HIGH_CPU
10   30          success  Thu Mar 6  00:31:12 2014  snmp                applet: HIGH_CPU
...but there seems to be a problem executing the script according to the logs:
002700: Mar  5 00:31:00.394 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:connect y
002701: Mar  5 00:31:00.438 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:terminal no exec prompt timestamp
002703: Mar  5 02:01:00.787 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:terminal exec prompt timestamp
002704: Mar  5 02:01:00.899 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:connect y
002705: Mar  5 02:01:00.911 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:terminal no exec prompt timestamp
002708: Mar  6 00:31:12.097 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:terminal exec prompt timestamp
002709: Mar  6 00:31:12.121 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:connect y
002710: Mar  6 00:31:12.145 cst: %PARSER-3-CFGLOG_NOMEM: User:    command:terminal no exec prompt timestamp
Really not sure what the issue is.  Seems like a pretty straightforward script.
Thanks for any assistance.
Joe Clarke
You need to add:
action 15 cli command "enable"
But it could also be that your router is out of memory, and the CLI cannot be execute.  You might also want to simplify this by doing:
action 25 cli command "del /force bootflash:high_cpu.txt"
action 30 cli command "show proc cpu sort | redirect bootflash:high_cpu.txt"
Then drop actions 40 and 50.  The way it's written now won't work as you'd have to add a "pattern" keyword to your action 30 anyway.
Thank you so much, Joseph.  You're the best.
For those who will read this post later, here are the 2 options I tried successfully in the lab:
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge entry-val 75 poll-interval 60
action 20 cli command "enable"
action 30 cli command "term exec prompt timestamp"
action 40 cli command "show process cpu sorted | redirect bootflash:high_cpu.txt" pattern "confirm"
action 50 cli command "y"
action 60 cli command "term no exec prompt timestamp"
action 40 cli command "delete /force bootflash:high_cpu.txt"
action 50 cli command "show process cpu sorted | redirect bootflash:high_cpu.txt"
