EEM script is stopped when router trigger message
CSCO12111341
Hello all,
is there any workaround for this problem.
when for example I want to use command in EEM:
 action 11 cli command "copy flash:down.txt run"
router probably trigger message if destination is really running-config and it completely stop EEM and command 12 is not accepted.
I have similar problem in case that i want to enter command: no ip nat inside source ....
Thank you so much in advance
best regards
Lubos
Joe Clarke
Use:
action 11 cli command "copy flash:down.txt run" pattern "runn"
action 12 cli command ""
