05-14-2023 08:58 PM - edited 05-14-2023 08:59 PM
I am working on a script in EEM that uses regexp to return results regarding 4g signal strength and GPS coordinates on a IR829 router.
This is the current script.
event manager applet test7
event none
action 010 cli command "enable"
action 020 cli command "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long"
action 030 regexp "([\_0-9\\-]+)" "$_cli_result" match result
action 040 file open test7.TXT flash:test7.TXT a+
action 050 file puts test7.TXT nonewline "$result"
action 060 file close test7.TXT
I am having issues with regexp as it is only returning the first match. For example the current output of the script only shows the current RSSI. I would like the script to return all values listed in the show cellular 0 command. See below:
Current Result:
-59
Wanted Result:
-59 -94 -16 2.4 38 23 20.5188 96 51 19.6884
Is it possible to get regexp to return all the matches or is there a better method to retrieve the results.
Any help would be greatly appreciated, thanks.
05-15-2023 04:36 AM - edited 05-15-2023 04:41 AM
Hello @kmd,
event none
action 030 set counter 0
action 040 foreach line "$_cli_result" {
action 050 regexp "([\_0-9\\-]+)" "$line" match result
action 060 file open test7.TXT flash:test7.TXT a+
action 070 file puts test7.TXT nonewline "$result "
action 080 file close test7.TXT
action 090 incr counter
}A counter is introduced to keep track of the number of matches found. The "foreach" loop iterates over each line in the output of the "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long" command. Inside the loop, the "regexp" action extracts the desired values from each line and appends them to the file "test7.TXT", separated by a space.
05-15-2023 03:38 PM - edited 05-15-2023 05:12 PM
Thanks for the response, M02@rt37
I have tried to put the script on the router but it doesn't like the "}" at the end of the script and comes back with "% Invalid input detected at '^' marker."
05-15-2023 04:44 PM
You don't specify the curly brackets at all - simply "action end" at the end of the loop block.
So:
action 100 end
Command reference: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/command/eem-cr-book/eem-cr-a1.html#wp3468947737
05-15-2023 07:53 PM
Hi @Rich R , I used the action 100 end and the script now runs. The problem is that it still only returns the first match. Is there something else not right in the script that is making it stop on the first match?
Output of script:
TEST-ROUTER#more test7.TXT
-47
See current script below:
event none
action 030 set counter "0"
action 040 foreach line "$_cli_result" "{"
action 070 file puts test7.TXT "$result "
action 090 increment counter
action 100 end
05-16-2023 02:37 AM
I think your problem there is using "{" as your line delimiter - there aren't even any of those in the result you're looking at so there will never be a match!
Looking at example at https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/eem/configuration/15-mt/eem-15-mt-book/eem-policy-cli.html.xml
action 100 foreach int $poll_interfaces action 101 cli command "en" action 102 cli command "show int $int summ | beg ------" action 103 foreach line $_cli_result "\n" action 105 regexp ".*[0-9]+\s+[0-9]+\s+[0-9]+\s+[0-9]+\s+[0-9]+\s+([0-9]+)\s+.*" $line junk rxps action 106 if $_regexp_result eq 1 action 107 if $rxps gt $max_rx_rate action 108 syslog msg "Warning rx rate for $int is > than threshold. Current value is $rxps (threshold is $max_rx_rate)" action 109 end action 110 end action 111 end action 112 end
You should probably also be using the new-line delimiter for your end of line match?
I also don't think the counter variable is serving any purpose so can be removed altogether as you set to zero then increment on each loop but it never gets used anywhere.
05-16-2023 04:59 PM - edited 05-16-2023 05:01 PM
Thanks for that @Rich R , I used your advice and have now revised the script again. It's working well but I am now running into an issue where I need multiple matches on a single line from the cli result.
Below is the result from the show command in the script. And the result from the current script. In the latitude and longitude lines, there are three results in each. The current script is only returning the first result from each line (Shown in bold). I need the script to return the other values from longitude and latitude (underlined) I'm unsure on what to change in the script to also allow it to return multiple matches from a single line.
Additional help on this would be awesome, thanks.
Current RSSI = -56 dBm
Current RSRP = -87 dBm
Current RSRQ = -12 dB
Current SNR = 3.0 dB
Latitude: 38 Deg 23 Min 20.5188 Sec North
Longitude: 96 Deg 51 Min 19.6884 Sec North
Output from current script:
-56 -87 -12 3 38 96
Output that I am trying to achieve:
-56 -87 -12 3 38 23 20.5188 96 51 19.6884
Here is a copy of the current script.
event none
action 1 cli command "enable"
action 2 cli command "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long"
action 3 foreach line "$_cli_result" "\n"
action 3.1 regexp "([\_0-9\\-]+)" "$line" match result
action 3.2 file open test7.TXT flash:test7.TXT a+
action 3.3 file puts test7.TXT nonewline "$result "
action 3.4 file close test7.TXT
action 3.5 end
05-15-2023 08:01 AM
Can you post the output of below command :
show cellular 0 all
05-15-2023 03:41 PM
The output from show cellular 0 all is super long and it has a lot of information I don't need.
This is the output from: show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long
Latitude: 0 Deg 0 Min 0 Sec North
Longitude: 0 Deg 0 Min 0 Sec North
05-16-2023 05:16 AM
To retrieve multiple matches using regular expressions (regexp) in EEM scripting, you can modify your existing script to use a loop. Here's an updated version of the script that will capture all the desired values:
event none
action 030 regexp "(\\S+)" "$_cli_result" matchall result
action 050 foreach item in result
action 060 file puts test7.TXT nonewline "$item "
action 070 end
action 080 file puts test7.TXT ""
action 090 file close test7.TXT
In this updated script, the "regexp" command is modified to use (\\S+), which matches any non-whitespace character sequence. The "matchall" keyword is used to capture all the matches into the "result" variable.
The script then opens the file, enters a loop using "foreach" to iterate over each item in the "result" list, and writes each item to the file with a space delimiter. Finally, it adds a newline to separate each set of matches and closes the file.
With this modification, the script will capture and write all the desired values to the output file, separated by spaces.
Note: Make sure you have sufficient file system space available on your router to accommodate the output file. Adjust the file path and name if necessary.
