04-09-2013 09:37 AM
Hi all,
I'm trying to write a script that allows the router to query for its configuration.
Every time the script reaches the following line
cli_exec $cli1(fd) "copy scp://user:pass@192.168.1.130//conf/$hostname start"
Am I missing something here ?
When I try the command via cli it works.
Sotiris
04-09-2013 03:19 PM
There were issues in older code where SSH-related commands would hang. What version of IOS is this?
04-10-2013 01:34 AM
Hi Joseph,
Thanks for your reply I'm using IOS 15.1.
To get the script working at the end I issued the command "file prompt quiet" to stop the system prompt when SCP is used.
Not sure if there is a way to have an interactive communication with the system using the tcl expect or if the messages are actually pipped back to the TCL script.
Sotiris
04-10-2013 06:26 AM
Instead of using cli_exec, you can use cli_write, then use cli_read_pattern to look for the prompt. Then respond to the prompt using cli_exec or another cli_write. In this way you can interact with the command. However, you are correct the command does need to print back to the VTY the Tcl script is running on and I believe that was the issue that Joe alluded to with SSH-related commands hanging - although I could be wrong I did not follow it that closely and it was a long while ago.
Mike
04-10-2013 08:06 AM
Thanks for your reply Mike,
This keeps getting stranger and stranger, this morning the script worked perfectly no problems as I mentioned above, now I test the script again after some changes not relevant to the scp and now scp fails.
I run a debug ip scp and I get the following
SCP: SSH Client connect failed
I will try with cli_write and cli_read_pattern but I'm not holding my breath.
I have checked with the remote linux box that has the configuration stored and I do not see any packets comming from the router I'm running the script.
Sotiris
