EEM to Shut and No Shut Interface
andrewfkay
I have confiugred EEM to track an IP SLA and shut interface Fa0 if it fails.  Then, at 23:00 each day (least disruptive to user traffic) open the Fa0 interface again.  I've got this part working fine except I want it to shut the interface down again if the interface remains down once it has been reopened.
At the moment, I don't think it's working because the track doesn't change state from up to down and therefore stays down.  Any ideas how to get this working (I'm new to EEM).
Andrew
Config:
track 100 rtr 99 reachability
delay down 5 up 5
ip sla 99
icmp-echo 10.51.145.3 source-interface fa0
frequency 10
ip sla schedule 99 life forever start-time now
event manager applet SHUT_FA0
event track 100 state down
action 0 cli command "enable"
action 1 cli command "conf t"
action 2 cli command "interface fa0"
action 3 cli command "shut"
action 4 cli command "end"
event manager applet NO_SHUT_FA0
event timer cron cron-entry "00 23 * * 0-6"
action 3 cli command "no shut"
8 Replies 8
andrewfkay
Ok, I've got a bit further with the below config but it seems to end at the 'wait 60' and not go any further.  Any ideas?
action 0.0 cli command "enable"
action 1.0 cli command "conf t"
action 2.0 cli command "interface fa0"
action 3.0 cli command "shut"
action 4.0 cli command "end"
event timer cron cron-entry "20 14 * * 0-6"
action 3.0 cli command "no shut"
action 4.5 wait 60
action 5.0 track read 100
action 5.5 if $_track_state eq down
action 6.0  cli command "enable"
action 6.5  cli command "conf t"
action 7.0  cli command "interface fa0"
action 7.5  cli command "shut"
action 8.0 end
The applet will stop executing after 20 seconds.  Adding a wait like this is not recommended (though you can make it work).  You could add a nested applet to do the countdown:
event manager environment q "
action 4.0 cli command "event manager applet RE_SHUT_FA0"
action 4.1 cli command "event timer countdown time 60"
action 4.2 cli command "action 1.0 if $_track_state eq down"
action 4.3 cli command "action 1.1 cli command enable"
action 4.4 cli command "action 1.2 cli command $q config t$q"
action 4.5 cli command "action 1.3 cli command $q interface fa0$q"
action 4.6 cli command "action 1.4 cli command shut"
action 4.7 cli command "action 1.5 cli command $q no event manager applet RE_SHUT_FA0$q"
action 4.8 cli command "action 1.6 end"
action 4.9 cli command "end"
That's great.  I'll give it a try.  Could you explain the '$q'?
This allows you to embed a quote in the nested applet.
Ok, my config now looks like this and I'm getting the following error message:
event timer cron cron-entry "37 15 * * 0-6"
Jul 12 14:37:00.108: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: _track_state
Jul 12 14:37:00.108: %HA_EM-3-FMPD_ERROR: Error executing applet NO_SHUT_FA0 statement 4.2
Jul 12 14:37:00.108: %HA_EM-4-FMPD_NO_ACTION: No action configured for applet RE_SHUT_FA0
Any ideas?
Sorry, try changing action 4.2 to:
action 4.2 cli command "action 1.0 if \$_track_state eq down"
Hi Joseph,
I have made the change but I'm still having problems.  I get the following message:
Also, it creates the applet RE_SHUT_FA0 but I would expect it to be removed after applet has run.  It remains in the running config.
Please add explanation of any changes as I'm an EEM beginner and I'd like to understand the config.
Andrew
Do this:
action 4.2 cli command "action 1.0 if \134044_track_state eq down"
The reason for this is that you have to escape the '$'.  It's tricky to do.  You need to use the octal escape sequence of \134 to get the '\\'.  Then when the parent applet runs, it will configure \044, which will turn into '$' by the parser.
The applet should be removed once you fix this error (assuming everything is typed correctly).
