EEM to trigger on IP SLA RTT threshold on 4331?
Larry Sullivan
Level 3
Level 3
Trying to find out how to get a Cisco 4331 EEM to trigger on IP SLA RTT threshold instead of timeout.  I found a configuration that seems like it might work, tested it on 1841 and it took the command (event ipsla operation-id 11 reaction-type rtt), but my 4331 doesn't have the EEM applet "event ipsla..." option.  Is there another method?  Why would a much more expensive router have less options when it comes to event types to trigger EEM?
Joe Clarke
It may depend on your license or perhaps the IPSLA event detector wasn't compiled into your image.  This has happened before due to resource concerns or simple oversight.  You could still make this work by triggering a syslog message with the threshold violation and have EEM react to that syslog:
ip sla enable reaction-alerts
ip sla logging traps
I don't have an example syslog off hand, but when you configure that, you should see the message generated, and then you can craft a syslog regexp for it.
7 Replies 7
balaji.bandi
can you post show version of the device.
BB
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
uptime is 3 weeks, 4 days, 3 hours, 51 minutes
Uptime for this control processor is 3 weeks, 4 days, 3 hours, 53 minutes
System returned to ROM by reload at 09:37:33 PDT Fri Sep 7 2018
System restarted at 09:32:36 PDT Mon Oct 1 2018
System image file is "bootflash:/isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bi"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          AdvUCSuiteK9          RightToUse     AdvUCSuiteK9
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             None             None             None
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
you can check the feature supported for your version
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
BB
Well see... that's kind of the problem. I know the command isn't supported under EEM on the 4331, per my original post. I am looking more for some inside knowledge on a reason why (is there some other method or feature I'm NOT aware of?) or was it removed for no reason? Is there a work around? Something a feature set list won't really assist with. Thanks anyways.
i looked at ipbase have EEM feature supported in 4331
can you post EEM script and what is the error you getting when you creating EEM event ?
BB
Yes, we have EEM set up on the 4331, so I know that is supoorted.  On an 1841 I can enter event trigger "event ipsla operation-id 11 reaction-type rtt".  But on the 4331, event trigger "ipsla" is no longer an option.
1841
(config-applet)#event ?
  application         Application specific event
  cli                 CLI event
  config              Configuration policy event
  counter             Counter event
  env                 Environmental event
  identity            Identity event
  interface           Interface event
  ioswdsysmon         IOS WDSysMon event
  ipsla               IPSLA Event
  neighbor-discovery  Neighbor Discovery event
  nf                  NF Event
  none                Manually run policy event
  oir                 OIR event
  resource            Resource event
  routing             Routing event
  rpc                 Remote Procedure Call event
  snmp                SNMP event
  snmp-notification   SNMP Notification Event
  snmp-object         SNMP object event
  syslog              Syslog event
  tag                 event tag identifier
  timer               Timer event
  track               Tracking object event
4331
  cli                 CLI event
  gold                GOLD event
  oir                 OIR event
  rf                  Redundancy Facility event
  snmp                SNMP event
  syslog              Syslog event
  timer               Timer event
Joe Clarke
