EMM Script Help
willijo73
Hello, first time here and looking for some assistance if possible. My client would like us to create and EMM script that would run every hour and send the information to the same output so we can pull the information once a day and send it to them. They are looking for show proc cpu history. Can anyone assist with this script. Any help would be greatly appreciated.
Francesco Molino
Before giving you an example, i bet you want to keep all outputs on 1 file right?
Can you issue the command:
Sh proc cpu | append flash:test.txt
If append doesn't work, i would suggest moving with a tcl script.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
