Error in ip configuring
krahulbgp
Level 2
Level 2
Why i am getting bad mask error can anyone explain ?
@krahulbgp
hi, this for subnet 255.255.255.252 you can have total 4 IP addresses with 2 usable IPs. for the IP you entered, network range is 201.0.0.0/30. so your 4 IPs will be 201.0.0.0, 201.0.0.1, 201.0.0.2 and 201.0.0.3. each network have 2 IPs for network and broadcast addresses.
201.0.0.0 - network address
201.0.0.3 - broad cast address
so you cannot use 201.0.0.3 for interface. you need to use 201.0.0.1 or 201.0.0.2
Good luck
KB
Joseph W. Doherty
Possibly the error message is misleading.  The IP address and network mask COMBINATION is invalid.  You need to change the IP address (as it's the broadcast address for an /30, as explained in @Kasun Bandara's reply) or the network mask (or both).
BTW that IP address would be valid in a /32, /31, /29, /28, . . .  Just not the /30.
