Error in LMS 3.2 Installation
Cesar TM
Hi!
I tried to install lms 3.2 on VMware EXS 3.5 Server with Windows 2003 EM / R2
When i launch the LMS install shield, after self-signed certificate confirmation step, appears this error:
An Error (-5011 : 0x80040705) has occured while running the setup.
Please make sure you have finished any previous setup and closed other applications.
If the error still occurs, please contact your vendor: Cisco Systems Inc.
Error Code: -5011 : 0x80040705
Error Information:
>SetupNew\setup.cpp (488)
PAPP:CiscoWorks
PVENDOR:Cisco Systems Inc.
PGUID:11B8350D-559C-45BE-8EDC-A7B2DA265F7F
$15.0.0.603PAK
@Windows Server2003 Service Pack 2 (3790)
5 Replies 5
Joe Clarke
Is this is a download, or are you installing from a DVD-created ISO image?
It may be a process previously
You referred to a previous installation of LMS? This is the first installation! Thanks
Hi, Joe
this is a Download installation file.
Sorry,
You have misunderstood or could not tell.
