Hi All,
We are facing connectivity issue ERROR_INTERNET_CONNECTION_RESET issue intermittently in the web browser while accessing the application. On checking with the networking team, we got the below error log
1 2014/06/01 01:00:15.648 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182684062 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1788 (18.91.214.41/1788)
2 2014/06/01 01:00:15.679 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182684062 for outside:162.230.23.245/443 to inside:18.91.214.41/1788 duration 0:00:00 bytes 7650 TCP Reset-O
3 2014/06/01 01:00:15.679 EST 10.249.3.8 %ASA-6-106015: Deny TCP (no connection) from 18.91.214.41/1788 to 162.230.23.245/443 flags PSH ACK on interface inside
4 2014/06/01 01:00:15.694 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342603073 for outside:162.230.23.245/443 to inside:18.91.214.41/1788 duration 0:00:00 bytes 0 Failover primary closed
5 2014/06/01 01:03:03.664 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755754 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1857 (18.91.214.41/1857)
6 2014/06/01 01:03:04.133 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755978 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1858 (18.91.214.41/1858)
7 2014/06/01 01:03:04.164 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755983 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1859 (18.91.214.41/1859)
8 2014/06/01 01:03:04.164 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755984 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1860 (18.91.214.41/1860)
9 2014/06/01 01:03:04.164 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755985 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1861 (18.91.214.41/1861)
10 2014/06/01 01:03:04.196 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182755988 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1862 (18.91.214.41/1862)
11 2014/06/01 01:03:04.539 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182756084 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1864 (18.91.214.41/1864)
12 2014/06/01 01:03:12.227 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755984 for outside:162.230.23.245/443 to inside:18.91.214.41/1860 duration 0:00:08 bytes 121977 TCP Reset-O
13 2014/06/01 01:03:12.227 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755983 for outside:162.230.23.245/443 to inside:18.91.214.41/1859 duration 0:00:08 bytes 38534 TCP Reset-O
14 2014/06/01 01:03:12.227 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661908 for outside:162.230.23.245/443 to inside:18.91.214.41/1860 duration 0:00:08 bytes 0 Failover primary closed
15 2014/06/01 01:03:12.227 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661907 for outside:162.230.23.245/443 to inside:18.91.214.41/1859 duration 0:00:08 bytes 0 Failover primary closed
16 2014/06/01 01:03:12.242 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755754 for outside:162.230.23.245/443 to inside:18.91.214.41/1857 duration 0:00:08 bytes 48317 TCP Reset-O
17 2014/06/01 01:03:12.242 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755978 for outside:162.230.23.245/443 to inside:18.91.214.41/1858 duration 0:00:08 bytes 19941 TCP Reset-O
18 2014/06/01 01:03:12.258 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755988 for outside:162.230.23.245/443 to inside:18.91.214.41/1862 duration 0:00:08 bytes 19957 TCP Reset-O
19 2014/06/01 01:03:12.258 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182755985 for outside:162.230.23.245/443 to inside:18.91.214.41/1861 duration 0:00:08 bytes 23876 TCP Reset-O
20 2014/06/01 01:03:12.258 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182756084 for outside:162.230.23.245/443 to inside:18.91.214.41/1864 duration 0:00:07 bytes 8652 TCP Reset-O
21 2014/06/01 01:03:12.258 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661718 for outside:162.230.23.245/443 to inside:18.91.214.41/1857 duration 0:00:08 bytes 0 Failover primary closed
22 2014/06/01 01:03:12.258 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661905 for outside:162.230.23.245/443 to inside:18.91.214.41/1858 duration 0:00:08 bytes 0 Failover primary closed
23 2014/06/01 01:03:12.258 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661909 for outside:162.230.23.245/443 to inside:18.91.214.41/1861 duration 0:00:08 bytes 0 Failover primary closed
24 2014/06/01 01:03:12.258 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661913 for outside:162.230.23.245/443 to inside:18.91.214.41/1862 duration 0:00:08 bytes 0 Failover primary closed
25 2014/06/01 01:03:12.289 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342661978 for outside:162.230.23.245/443 to inside:18.91.214.41/1864 duration 0:00:07 bytes 0 Failover primary closed
26 2014/06/01 01:03:12.305 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182759495 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1865 (18.91.214.41/1865)
27 2014/06/01 01:03:12.336 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182759495 for outside:162.230.23.245/443 to inside:18.91.214.41/1865 duration 0:00:00 bytes 8652 TCP Reset-O
28 2014/06/01 01:03:12.336 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342664757 for outside:162.230.23.245/443 to inside:18.91.214.41/1865 duration 0:00:00 bytes 0 Failover primary closed
29 2014/06/01 01:07:45.385 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182875631 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1913 (18.91.214.41/1913)
30 2014/06/01 01:07:45.416 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182875644 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1914 (18.91.214.41/1914)
31 2014/06/01 01:07:45.619 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182875644 for outside:162.230.23.245/443 to inside:18.91.214.41/1914 duration 0:00:00 bytes 6437 TCP Reset-O
32 2014/06/01 01:07:45.635 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342759658 for outside:162.230.23.245/443 to inside:18.91.214.41/1914 duration 0:00:00 bytes 0 Failover primary closed
33 2014/06/01 01:07:49.760 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342759652 for outside:162.230.23.245/443 to inside:18.91.214.41/1913 duration 0:00:04 bytes 0 Failover primary closed
34 2014/06/01 01:07:49.760 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182875631 for outside:162.230.23.245/443 to inside:18.91.214.41/1913 duration 0:00:04 bytes 6437 TCP Reset-O
35 2014/06/01 01:07:49.760 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182877582 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1917 (18.91.214.41/1917)
36 2014/06/01 01:07:49.791 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182877582 for outside:162.230.23.245/443 to inside:18.91.214.41/1917 duration 0:00:00 bytes 6437 TCP Reset-O
37 2014/06/01 01:07:49.791 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342761257 for outside:162.230.23.245/443 to inside:18.91.214.41/1917 duration 0:00:00 bytes 0 Failover primary closed
38 2014/06/01 01:07:52.510 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182878930 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1918 (18.91.214.41/1918)
39 2014/06/01 01:07:52.541 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182878930 for outside:162.230.23.245/443 to inside:18.91.214.41/1918 duration 0:00:00 bytes 6437 TCP Reset-O
40 2014/06/01 01:07:52.557 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182878949 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1919 (18.91.214.41/1919)
41 2014/06/01 01:07:52.557 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342762395 for outside:162.230.23.245/443 to inside:18.91.214.41/1918 duration 0:00:00 bytes 0 Failover primary closed
42 2014/06/01 01:07:52.572 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342762399 for outside:162.230.23.245/443 to inside:18.91.214.41/1919 duration 0:00:00 bytes 0 Failover primary closed
43 2014/06/01 01:07:52.572 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182878949 for outside:162.230.23.245/443 to inside:18.91.214.41/1919 duration 0:00:00 bytes 6437 TCP Reset-O
44 2014/06/01 01:07:55.338 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182880080 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1920 (18.91.214.41/1920)
45 2014/06/01 01:07:55.338 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182880084 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1921 (18.91.214.41/1921)
46 2014/06/01 01:07:56.041 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182880084 for outside:162.230.23.245/443 to inside:18.91.214.41/1921 duration 0:00:00 bytes 9685 TCP Reset-O
47 2014/06/01 01:07:56.041 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342763315 for outside:162.230.23.245/443 to inside:18.91.214.41/1921 duration 0:00:00 bytes 0 Failover primary closed
48 2014/06/01 01:07:58.447 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182880080 for outside:162.230.23.245/443 to inside:18.91.214.41/1920 duration 0:00:03 bytes 9711 TCP Reset-O
49 2014/06/01 01:07:58.463 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342763313 for outside:162.230.23.245/443 to inside:18.91.214.41/1920 duration 0:00:03 bytes 0 Failover primary closed
50 2014/06/01 01:08:03.322 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182883501 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1925 (18.91.214.41/1925)
51 2014/06/01 01:08:04.807 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182884107 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1927 (18.91.214.41/1927)
52 2014/06/01 01:08:04.916 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182883501 for outside:162.230.23.245/443 to inside:18.91.214.41/1925 duration 0:00:01 bytes 22419 TCP FINs
53 2014/06/01 01:08:04.916 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342766149 for outside:162.230.23.245/443 to inside:18.91.214.41/1925 duration 0:00:01 bytes 0 Failover primary closed
54 2014/06/01 01:08:06.088 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342766649 for outside:162.230.23.245/443 to inside:18.91.214.41/1927 duration 0:00:01 bytes 0 Failover primary closed
55 2014/06/01 01:08:06.088 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182884676 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1928 (18.91.214.41/1928)
56 2014/06/01 01:08:06.088 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182884107 for outside:162.230.23.245/443 to inside:18.91.214.41/1927 duration 0:00:01 bytes 5167 TCP FINs
57 2014/06/01 01:08:06.088 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182884683 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1929 (18.91.214.41/1929)
58 2014/06/01 01:08:06.088 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182884684 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1930 (18.91.214.41/1930)
59 2014/06/01 01:08:11.291 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182884676 for outside:162.230.23.245/443 to inside:18.91.214.41/1928 duration 0:00:05 bytes 1919 TCP FINs
60 2014/06/01 01:08:11.291 EST 10.249.3.8 %ASA-6-106015: Deny TCP (no connection) from 18.91.214.41/1928 to 162.230.23.245/443 flags RST on interface inside
61 2014/06/01 01:08:11.291 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342767141 for outside:162.230.23.245/443 to inside:18.91.214.41/1928 duration 0:00:05 bytes 0 Failover primary closed
62 2014/06/01 01:08:17.823 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342767149 for outside:162.230.23.245/443 to inside:18.91.214.41/1930 duration 0:00:11 bytes 0 Failover primary closed
63 2014/06/01 01:08:17.823 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182884684 for outside:162.230.23.245/443 to inside:18.91.214.41/1930 duration 0:00:11 bytes 10604 TCP FINs
64 2014/06/01 01:08:17.854 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182884683 for outside:162.230.23.245/443 to inside:18.91.214.41/1929 duration 0:00:11 bytes 18930 TCP FINs
65 2014/06/01 01:08:17.869 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342767148 for outside:162.230.23.245/443 to inside:18.91.214.41/1929 duration 0:00:11 bytes 0 Failover primary closed
66 2014/06/01 01:08:18.229 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182889513 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1933 (18.91.214.41/1933)
67 2014/06/01 01:08:19.510 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182889513 for outside:162.230.23.245/443 to inside:18.91.214.41/1933 duration 0:00:01 bytes 5657 TCP FINs
68 2014/06/01 01:08:19.526 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342771232 for outside:162.230.23.245/443 to inside:18.91.214.41/1933 duration 0:00:01 bytes 0 Failover primary closed
69 2014/06/01 01:08:19.588 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182890071 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1939 (18.91.214.41/1939)
70 2014/06/01 01:08:24.635 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182890071 for outside:162.230.23.245/443 to inside:18.91.214.41/1939 duration 0:00:05 bytes 1919 TCP FINs
71 2014/06/01 01:08:24.635 EST 10.249.3.8 %ASA-6-106015: Deny TCP (no connection) from 18.91.214.41/1939 to 162.230.23.245/443 flags RST on interface inside
72 2014/06/01 01:08:24.651 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342771680 for outside:162.230.23.245/443 to inside:18.91.214.41/1939 duration 0:00:05 bytes 0 Failover primary closed
73 2014/06/01 01:08:27.244 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182893340 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1962 (18.91.214.41/1962)
74 2014/06/01 01:08:27.291 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182893355 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1968 (18.91.214.41/1968)
75 2014/06/01 01:08:27.791 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182893588 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/1970 (18.91.214.41/1970)
76 2014/06/01 01:08:33.276 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182893355 for outside:162.230.23.245/443 to inside:18.91.214.41/1968 duration 0:00:05 bytes 1919 TCP FINs
77 2014/06/01 01:08:33.276 EST 10.249.3.8 %ASA-6-106015: Deny TCP (no connection) from 18.91.214.41/1968 to 162.230.23.245/443 flags RST on interface inside
78 2014/06/01 01:08:33.276 EST 10.249.3.8 %ASA-6-106015: Deny TCP (no connection) from 18.91.214.41/1968 to 162.230.23.245/443 flags RST on interface inside
79 2014/06/01 01:08:33.276 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342774322 for outside:162.230.23.245/443 to inside:18.91.214.41/1968 duration 0:00:05 bytes 0 Failover primary closed
80 2014/06/01 01:08:46.823 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182893340 for outside:162.230.23.245/443 to inside:18.91.214.41/1962 duration 0:00:19 bytes 26543 TCP FINs
81 2014/06/01 01:08:46.823 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342774306 for outside:162.230.23.245/443 to inside:18.91.214.41/1962 duration 0:00:19 bytes 26520 Failover primary closed
82 2014/06/01 01:08:47.260 EST 10.249.3.8 %ASA-6-302013: Built outbound TCP connection 3182901788 for outside:162.230.23.245/443 (162.230.23.245/443) to inside:18.91.214.41/2006 (18.91.214.41/2006)
83 2014/06/01 01:08:52.385 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182901788 for outside:162.230.23.245/443 to inside:18.91.214.41/2006 duration 0:00:05 bytes 1919 TCP FINs
84 2014/06/01 01:08:52.417 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342781114 for outside:162.230.23.245/443 to inside:18.91.214.41/2006 duration 0:00:05 bytes 0 Failover primary closed
85 2014/06/01 01:09:03.479 EST 10.249.3.8 %ASA-6-302014: Teardown TCP connection 3182893588 for outside:162.230.23.245/443 to inside:18.91.214.41/1970 duration 0:00:35 bytes 129684 TCP FINs
86 2014/06/01 01:09:03.495 EST 10.249.3.9 %ASA-6-302014: Teardown TCP connection 342774497 for outside:162.230.23.245/443 to inside:18.91.214.41/1970 duration 0:00:35 bytes 129661 Failover primary closed
Since we are not familiar with debugging network logs, can someone please help us to understand what the issue could be?
