03-31-2022 09:40 PM - edited 04-04-2022 08:09 PM
Hello team,
I’m having issue with EVE-NG management cloud. I’m using Linux Ubuntu 20.04 as my OS, and VMware Workstation as my hypervisor. I set eve-ng network adapter to be bridged in VMware, then I open EVE-NG web page and create a new lab and add a management cloud to let the devices (VPCS) in my topology get an IP address via DHCP. However, my VPSC doesn’t work at all! And it displays Good-bye.
Welcome to Virtual PC Simulator, version 1.0 (0.8c)
Dedicated to Daling.
Build time: Dec 31 2016 01:22:17
Copyright (c) 2007-2015, Paul Meng (mirnshi@gmail.com)
All rights reserved.
VPCS is free software, distributed under the terms of the "BSD" licence.
Source code and license can be found at vpcs.sf.net.
For more information, please visit wiki.freecode.com.cn.
Modified version supporting unetlab by unetlab team
Press '?' to get help.
Good-bye
And when I connect my VPCS to any other cloud (cloud 2 or 3 for example) the VPCS works fine.
I deployed a new EVE-NG image and still got the same result.
How can I fix that? I want to use the management cloud to give the VPCS IP via DHCP.
Note that even if I try any other device, like Linux for example, and connect it to the management cloud, I still don't get IP via DHCP.
Please help
Solved! Go to Solution.
03-31-2022 09:57 PM
that's a bug actually original maintainer given the best ability of the program for us to use the small tiny client to test as an end device test in our labs, this vpcs can not be full-blown clients like any other IOS or windows or linux tiny image.
03-31-2022 09:57 PM
04-01-2022 08:30 AM
the VPCS is not the issue.
the issue is the management cloud. if I connect any type of device (VPCS or Linux VM) to this management cloud, it doesn't get an IP address from the DHCP server.
but if I connect the VPCS to a cisco router that is a DHCP server, the VPCS works fine and get IP from the router.
so the problem here is the management could in EVE-NG
04-01-2022 11:05 AM
I don't want to take credit for somebody else's suggestion, but check ALFREDO.G.SANGIULIANO's post in the thread below:
https://community.cisco.com/t5/routing/eve-ng-management-cloud-issue/td-p/3957909
04-01-2022 11:13 AM
Hi Georg,
I actually tried Alfredo's solutions but still have the same issue.
04-01-2022 11:48 AM
can you summarize what you have already tried, so we don't come up with anything redundant ?
04-04-2022 08:42 PM - edited 04-04-2022 08:44 PM
1. I tried installing new EVE-NG image, and the management cloud still not working.
2. I tried Alfredo's solution and the mgmt cloud still doesn't work
