Event Manager Applet not triggering
DeckersEMEA
Wondering if you can help me here.
I have a DMVPN tunnel that flaps occasionally on the remote end, and a 'clear crypto sa' on the remote fixes it, looking a the logs on the remote, its always the same error message received -
%DUAL-5-NBRCHANGE: EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down: holding time expired
I have created an Event applet to run the 'clear crypto sa' command if this syslog message is seen, but I cannot get it to trigger.
My Event manager applet is as follows -
event manager applet Tunnel3Down
event syslog pattern ".*EIGRP-IPv4 60.*"
action 1.0 cli command "enable"
action 2.0 cli command "clear crypto sa"
action 3.0 syslog msg "Tunnel 3 is down, clearing crypto isakmp"
I tried with the full sting that is displayed in the syslog as my syslog pattern but that did not work so I then trimmed down the pattern and included wildcards of .* at beginning and end to try and catch it, but that is also not triggering,
I've just had the syslog message occur and there is no sign of the Event Manager Applet triggering (or I would see the Tunnel 3 is down lessage
000854: Oct 26 08:11:22.489 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down: holding time expired
000855: Oct 26 08:12:26.405 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down: holding time expired
000856: Oct 26 08:13:04.545 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is up: new adjacency
000857: Oct 26 08:14:34.901 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is up: new adjacency
Can anyone advise what I am doing wrong? its driving me crazy.
Just to add its on a Cisco 1921 -
Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Thanks in advance.
Use this for your pattern:
.*EIGRP-IPv4 55: Neighbor 192.168.205.254 .Tunnel2. is down:.*
13 Replies 13
Joe Clarke
I think this "clear" command is interactive.  That is, if you run it manually, are you prompted to confirm before you get the device prompt back?  If so, what is the prompt?
Also, if you use AAA command authorization, you will need to either configure:
event manager session cli user USER
Or add "authorization bypass" to your applet definition line.
Note: in all cases, adding "debug event manager action cli" will help show what is happening.
I am running into this similar problem. The only difference is I am trying to configure a T1 interface when the module is inserted. The EEM script is looking for the the log message for T1 card to be online (which comes up), but EEM script does not trigger.
event manager applet bringupt1
event syslog pattern "SPA (NIM-2MFT-T1/E1) online in subslot 0/1"
action 1.0 cli command "config t"
action 2.0 cli command "card type t1 0 1"
action 3.0 cli command "controller T1 0/1/0"
action 4.0 cli command "end"
action 5.0 cli command "write mem"
Nothing happens when the log message show up.
This is what I see when I run "event manager run bringupt1"
router#event manager run bringupt1
EEM policy bringupt1 not registered with event none Event Detector
But when I execute "show event manager "show event manager policy registered" it policy does show up.
"event manager session cli user USER" does not show anything for me, but here is what I see from "debug event manager all"
000688: *Oct 27 15:21:21.902: cli_history_entry_add: free_hist_list size=0, hist_list size=7
000689: *Oct 27 15:21:21.902: check_eem_cli_policy_handler: command_string=event manager run bringupt1
000690: *Oct 27 15:21:21.902: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
000691: *Oct 27 15:22:00.000: fh_fd_timer_process_async
000697: *Oct 27 15:26:59.999: fh_fd_timer_process_async
Any suggestions please??
You have a different problem.  Please start a new thread for your issue.
Looks like my eem script is working, its kind of strange that as soon as I start matching two different parts of the same syslog, the script started working.
Here is the working script:
event syslog pattern "NIM-2MFT-T1/E1.* online in subslot 0/1" period 1     <---- I changed this line.
Hi, so i added the - event manager session cli username "USERNAME" command
and also added the event dubug, the DMVPN Tunnel went down this morning, but nothing triggered, this is the script i have on the router -
event syslog pattern ".*EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down:*."
action 3.0 syslog msg "Tunnel 3 is DOWN, clearing Crypto isakmp"
This is the output of the log
000916: Oct 28 08:01:26.702 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down: holding time expired
000917: Oct 28 08:02:48.578 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is up: new adjacency
I cant see anything wrong here, but no debug log was triggered. Anyone know why?
The only error I see is you have:
When you need:
.*EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down:.*
Hi, so I made the change from *. to .* but it still does not seem to be working, here is the latest log, sh debug, event section of config  and sh event manager policy registered commands
Do debug is occurring event though the policy is registered,
000978: Oct 31 13:46:33.842 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down: Peer Termination received
000979: Oct 31 13:46:38.566 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is up: new adjacency
000980: Oct 31 14:01:59.914 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down: Peer Termination received
000981: Oct 31 14:02:03.478 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is up: new adjacency
000982: Oct 31 14:02:30.174 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down: Peer Termination received
000983: Oct 31 14:02:34.678 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is up: new adjacency
000984: Oct 31 14:04:31.234 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down: Peer Termination received
000985: Oct 31 14:04:35.854 PCTime: %DUAL-5-NBRCHANGE: EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is up: new adjacency
20001-1921# sh debug
Embedded Event Manager:
  Debug EEM action cli debugging is on
20001-Berlin-1921#sh run | sec event
 event syslog pattern ".*EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down:.*"
 action 2.5 cli command "ping 10.14.10.10 repeat 100"
event manager applet Tunnel2Down authorization bypass
 event syslog pattern ".*EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down:.*"
 action 3.0 syslog msg "Tunnel 2 is DOWN, clearing Crypto isakmp"
event manager applet Tunnel1Down authorization bypass
 event syslog pattern ".*EIGRP-IPv4 50: Neighbor 192.168.200.254 (Tunnel1) is down:.*"
 action 3.0 syslog msg "Tunnel 1  is DOWN, clearing Crypto isakmp"
20001-1921#sh event man pol reg
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    applet    user    syslog              Off   Mon Oct 30 09:27:10 2017  Tunnel3Down
 pattern {.*EIGRP-IPv4 60: Neighbor 192.168.201.254 (Tunnel3) is down:.*}
 maxrun 20.000
2    applet    user    syslog              Off   Mon Oct 30 09:27:11 2017  Tunnel2Down
 pattern {.*EIGRP-IPv4 55: Neighbor 192.168.205.254 (Tunnel2) is down:.*}
 maxrun 20.000
3    applet    user    syslog              Off   Mon Oct 30 09:27:16 2017  Tunnel1Down
 pattern {.*EIGRP-IPv4 50: Neighbor 192.168.200.254 (Tunnel1) is down:.*}
 maxrun 20.000
Any advise?
Yes, swapping the () for . seems to have fixed it, thanks for your help.
dear sir
kindly, command not work..
You’re missing the double quotes around the syslog pattern. Everything after the pattern keyword needs to be quoted.
Dear sir
Many thanks it’s working now
