Failover Master in Mobility Express
Set Paing
Beginner
Beginner
Master AP does not send the controller configuration to subordinate ap during the process of failover master. After electing master ap, the master ap should send the configuration of controller to the subordinate ap. In my network, the configuration does not send. How can I fix it?
Flavio Miranda
VIP Advisor VIP Advisor
VIP Advisor
Hi @Set Paing
If you are talking about master failover I think this process is different.
 Unless you define a master, an algorithm will elect one for you. If this elected master fail, the subordinates APs will fallback to standalone mode and a new master election will take place.
 As per the documentation I've read, I see no mention to Configuration exchange between APs.
-If I helped you somehow, please, rate it as useful.-
Recognize Your Peers
