Features of Cisco Prime Infrastructure
nayanpanchal
Dear Expert,
We have a requirement for Network Management Solution. We have a very high level requirement. I've prepared the response. However, I'm missing some information. Your comment would be very helpful on that.
1.         Real-time monitoring for the network status & performance. - Supported
2.         Real-time & dynamic Network Maps - Supported - Supported
3.         Real-time monitoring the resources utilization(CPU, Memory, environment, etc) in the network devices (Routers & Switches). - Supported
4.         Capable for importing Syslog. - Supported
5.         Capable for using SNMP, WMI, and CLI(SSH, Telnet). - Supported
6.         Capable for monitoring the IPSLA. - Supported
7.         Capable for importing and analyzing the network traffic NetFlow (sFlow, JFlow, etc). - NetFlow Supported
8.         Provides in-depth Reports - Supported
9.         Provides a User-Friendly Web-Access. - Supported
10.       Provides a customizable Dashboards. - Supported
11.       Modem-based SMS incident-based alerting (Add-on) - Ready to be integrated with any SNMPv3 based Alerting System (Remedy)
12.       Redundant Servers where the solution will be deployed & and the OS must be chosen based on the solution platform (Linux or Windows, etc).               - Redundant Appliance can be configured.
13.       Solution has to be flexible, customizable, scalable, distributed and reliable.- Supported
14.       Providing Fault correlation/root cause analysis and filtering. - Partially Supported
15.       Providing alerting. - Supported
16.       Providing configuration Management. - Supported
17.       Provide QoS monitoring.- Supported
18.       Providing FCAPS functions (Fault, Capacity, Accounting, Performance & Security) Application & Servers Monitoring - Should be part of                    Server Monitoing system
19.       Real-time monitoring the resources utilization(CPU, Memory, HD, Network usage) - Should be part of Server Monitoing system
Your comments are highly appreciated.
Thanks.
Leo Laohoo
What version?  CPI does NOT support Windows.
CPI 2.0 and onwards requires ESX/ESXi.
tadeseg01
@nayanpanchal wrote:
Dear Expert,
Thanks.
