Felxible Netlow not being exported thru management VRF
we hav just installed an ISR 4431 as internet router.
and has the gi0 as management interface, so want to export FNF thru the management port. SNMP is working ok thru the Mgmt-intf
ping is ok
ping vrf Mgmt-intf 10.1.0.234
Sending 5, 100-byte ICMP Echos to 10.1.0.234, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
but nothing is sent see config extract  below
can ping Mgmt-intf 10.1.0.234
flow exporter Prime_exporter
 description Exports netflow data to Cisco Prime
 destination 10.1.0.234 vrf Mgmt-intf
 transport udp 9991
flow monitor Prime
 record Netflow
interface GigabitEthernet0/0/0
  ip flow monitor Prime input
 ip flow monitor Prime output
sh flow exp stat
Flow Exporter Prime_exporter:
  Packet send statistics (last cleared 00:22:36 ago):
    Successfully sent:         0                     (0 bytes) <Nothing sent
    Reason not given:          307                   (88264 bytes)
  Client send statistics:
    Client: Flow Monitor Prime
      Records added:           2286
        - failed to send:      2286
      Bytes added:             70866
        - failed to send:      70866
Is there any special license required?
marce1000
 - Sending Netflow packtets trough the management port (VRF) is unsupported.
M.
I think it is now otherwise why would the command " destination 10.1.0.234 vrf Mgmt-intf '
be accepted in the flow exporter configuration??
I was thinking more in the line of a License issue with the ISR 4400
