FInding correct OID
fitzie
I'm looking for the correct MIB and OID to consult to find a particular string for all of my devices.
In Prime Infrastructure, this field is known as the Device Type.  I can export it, but I'm looking for the correct variable to grab via SNMP.  I looked in the CISCO-PRODUCTS-MIB, but didn't find it there.
Sample device types:
Cisco 2921 Integrated Services Router G2
Cisco 3750 Stackable Switches
Cisco 4321 Integrated Services Router
Cisco 4331 Integrated Services Router
Cisco 4351 Integrated Services Router
Cisco 4451 Series Integrated Services Router
Cisco 5508 Wireless LAN Controller
Cisco 7204VXR Router
Cisco 8540 Series Wireless Controllers
Cisco ASR 1002 Router
Cisco ASR 1002-HX Router
Cisco ASR 1002-X Router
Cisco Catalyst 2950G 48 EI Switch
Cisco Catalyst 2960C-12PC-L Switch
Cisco Catalyst 29xx Stack-able Ethernet Switch
Cisco Catalyst 3560CG-8PC-S Compact Switch
Cisco Catalyst 3560CX-12PC-S Switch
Cisco Catalyst 3560CX-8PC-S Switch
Cisco Catalyst 3560CX-8PT-S Switch
Cisco Catalyst 35xx Stack-able Ethernet Switch
Cisco Catalyst 3850-48U-E Switch
Cisco Catalyst 4900M Switch
Cisco Catalyst 6500 Virtual Switching System
Cisco Catalyst 6506 Switch
Cisco Catalyst 6509 Switch
Cisco Catalyst 6513 Switch
Cisco Catalyst 6807-XL Switch
Cisco Catalyst 68xx Virtual Switch
Cisco Catalyst 9500 Switch
Cisco Catalyst38xx stack-able ethernet switch
Cisco Nexus 5548UP Switch
Cisco Nexus 5672UP Switch
Cisco Nexus 7000 10-Slot Switch
Cisco Nexus 9372PX-E Switch
Cisco Nexus 9372TX Switch
Cisco Nexus 9396PX Switch
balaji.bandi
Sorry, you mentioned you tried some URL and not able to get one.
is this one below (if this is case apologies for same URL providing here)
https://mibs.cloudapps.cisco.com/ITDIT/MIBS/servlet/index
BB
susheel0417
If you are looking for OIDs of interfaces, then try the below commands
Cisco IOS - show snmp mib ifmib ifindex | include GigabitEthernet1/1 (or any interface)
Cisco NX-OS - show interface snmp-ifindex | include Eth1/5
Please like this reply if it solves your issue!
