11-20-2017 12:39 PM - edited 03-01-2019 06:15 PM
According to the instructions from Cisco, I need to
1. set the laptop IP to 192.168.45.2/24 (check)
# ifconfig
em1 Link encap:Ethernet HWaddr 34:E6:D7:53:45:D5
inet addr:192.168.45.2 Bcast:192.168.45.255 Mask:255.255.255.0
inet6 addr: fe80::36e6:d7ff:fe53:45d5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:62 errors:0 dropped:0 overruns:0 frame:0
TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:34100 (33.3 KiB) TX bytes:4460 (4.3 KiB)
Interrupt:20 Memory:f7d00000-f7d20000
2. set the default route to 192.168.45.1 (check)
# ip route
192.168.45.0/24 dev em1 proto kernel scope link src 192.168.45.2 metric 1
default via 192.168.45.1 dev em1 proto static
3. connect to the management port (check)
Now I should be able to connect to http://192.168.45.45. However I cannot and nmap reports that both ports 80 and 443 are filtered*.
# nmap -sT -p 80,443 -P0 192.168.45.45
Nmap scan report for 192.168.45.45
Host is up (1.00s latency).
PORT STATE SERVICE
80/tcp filtered http
443/tcp filtered https
Is there something else I need to do? I did power it on :)
* From the man page: "filtered means that a firewall, filter, or other network obstacle is blocking the port so that Nmap cannot tell whether it is open or closed."
Solved! Go to Solution.
11-20-2017 06:42 PM
Is the FMC 1000 new or previously used?
If the latter, it may have been setup with something other than the default address. You should be able to check it via console. (i.e. directly connect a monitor and keyboard)
11-20-2017 06:42 PM
11-21-2017 10:22 AM
It is supposed to be new but who knows. I see if I can get attached with a monitor
