05-20-2015 12:12 AM
I got something question below.
please let me know what is this happening.
Thanks for replies!!
show ver : Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9_NPE-M), Version 15.0(1)SY2, RELEASE SOFTWARE (fc4)
IOS : bootdisk:s2t54-ipservicesk9_npe-mz.SPA.150-1.SY2.bin
- configuration -
flow record TEST
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
flow exporter TEST
destination 1.1.1.1
transport udp 2055
export-protocol netflow-v5
flow monitor TEST
record TEST
exporter TEST
cache timeout inactive 300
cache timeout active 60
sampler TEST
mode random 1 out-of 1024
int vlan 10
ip address 10.10.10.1 255.255.255.0
ip flow monitor TEST sampler TEST input
ip access-group vlan10 in
ip access-group vlan10 out
I got following logs : %FMCORE-4-RACL_REDUCED: Interface Vlan10 routed traffic will be software switched in ingress direction.
L2 features may not be applied at the interface
Q1. what is this logs?
Q2. In order to enable Flexible Netflow, What shall I do?
05-20-2015 02:04 AM
Hi there's my working flexible netflow from our vss
The log looks like a memory leak
https://tools.cisco.com/quickview/bug/CSCtx62375
flow record FLOW-RECORD
description record to monitor network traffic
match ipv4 tos
match ipv4 protocol
match interface input
match interface output
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter NetQos
description export Netflow traffic to HQ
destination x.x.x.x
source Loopback3
template data timeout 300
option interface-table timeout 1000
option exporter-stats timeout 1000
flow monitor DGH_nq
description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
record FLOW-RECORD
exporter NetQos
statistics packet protocol
ip flow monitor DGH_nq input
ip flow monitor DGH_nq output
