Force ether-channel use all interface
Hi Dear i Have ether-channel port with 2 10G port but show etherchannel summary
100 Po100(SU) LACP Te1/0/16(P) Te1/0/17(P)
And
Number of aggregators: 1
Show me 1 port
How Force Used 2 ports In ether-Channel
balaji.bandi
Both ports already bundled in the Port-channel,
you need to configure port-channel load-balance to use both..
https://packetpushers.net/understand-etherchannel-load-balancing-catalyst-switches/
BB
Hi Dear
I Use port-channel loadbalancig src-mac on both site For L2 etherchannel
But BW still 1 interface
What platform is this? And what version of code is it running? Would you post the output of show interface status? Perhaps if you share details of the configuration we might get some insight into the issue.
Rick
Rick
