02-07-2021 02:01 PM
Hi there, i have a Cisco ASR-920-4SZ-A acting as a Bras on which end users connect. the router acts as a DHCP server. we are installing a bandwidth shaper into our network and this bandwidth shaper will be located within our core network while the Bras is located remotely. the bandwidth shaper will need to have access to DHCP information, particularly the DHCP binding table to know the list of IP addresses that an end user device has acquired.
What values do i need to set on the router to forward the DHCP info to the bandwidth shaper?
I need assistance with this.
Solved! Go to Solution.
02-07-2021 08:00 PM
Is you bandwidth shaper support radius messages as a radius server? You can send a radius accounting from your dhcp pool on your router when an IP is assigned or released for a client.
You can also configure your router to save all binding in a local text file (or remote text file), is this something that could work?
02-10-2021 08:09 PM
Hi sir, if you don't mind i would like you to verify my configuration for this. here is what i've got setup. did i get the config right?
aaa new-model
aaa group server radius test-radius
server 172.31.34.33 acct-port 1813
ip dhcp pool Pool_101
vrf DATA
accounting test-radius
02-07-2021 08:00 PM
02-07-2021 08:05 PM
Hi there, thank you for your reply. Are you able to point me to a link with a sample configuration for the radius accounting option?
Jethro
02-07-2021 08:23 PM
You need to configure aaa radius first (basic config you can look on any cisco documentation for AAA RADIUS) and then, under your local pool, the command is accounting xxxxx where xxxx corresponds to the aaa list you configured previously
02-07-2021 08:32 PM
Thank you for that. I will give that a try.
02-07-2021 08:37 PM
You're welcome. Keep us posted
02-10-2021 08:09 PM
aaa new-model
vrf DATA
