get as much info out of 50 cisco devices
mathew43
 I need to get as much info out of 50 cisco devices.
I have a TFTP server going, I have been running this command copy running-config TFTP://10.10.10.10/filename.txt
Which is great, but I need more info.  I need the info in Show Version (copy show version to TFTP doesn't work)
Also is there a way to use the command copy running-config TFTP://10.10.10.10/%hostname%.txt
%hostname% meaning saving the file as the hostname automatically, so I don't have to type in 50 hostname when exporting to TFTP
thx for any help.
#show version | redirect ?  thx!!
5 Replies 5
balaji.bandi
You can do a simple automated backup script to backup all devices with device names:
https://github.com/AlexMunoz905/Python-Cisco-Backup
flash0: Uniform Resource Locator
flash1: Uniform Resource Locator
flash2: Uniform Resource Locator
flash3: Uniform Resource Locator
flash: Uniform Resource Locator
ftp: Uniform Resource Locator
http: Uniform Resource Locator
https: Uniform Resource Locator
nvram: Uniform Resource Locator
rcp: Uniform Resource Locator
scp: Uniform Resource Locator
tftp: Uniform Resource Locator
BB
thx! I will take a look.  I appreciate your help
glad that command was helpful..
BB
nice code!  Just a nitpicky suggestion, but you should be using a context manager for writing to files.... instead of
    fileName = hostname + "_" + dt_string
    # Creates the text file in the backup-config folder with the special name, and writes to it.
    backupFile = open("backup-config/" + fileName + ".txt", "w+")
    backupFile.write(output)
    print("Outputted to " + fileName + ".txt!")
I would use:
    fileName = f"backup-config/{hostname}_{dt_string}.txt"
    with open(fileName, "w+") as backupFile:
There are several benefits to using a context manager, but most importantly, without a backupFile.close() call, the file stays open.  Also, f-strings are your friend!!!  They seem foreign at first, but with a little practice they really clean up the code and make it easier to read.  Just my 2 cents... Keep grinding
