01-05-2014 05:39 AM
Hi Team,
We are getting high cpu Spike in our all distribution switches in many locations.
Also we found our Cisco prime infrastructure causing the high cpu.but the spike only for 20 to 30 seconds.
If we deny the PI there will be no CPU spike..
Is there any troubleshooting or configuration need to done for this issue..but we are getting in all our sites due to this in different cpu process I'd ..
Affected sup like 720 but in core we are not getting that issue with same sup and ios.
Kindly suggest any action plan regarding the high cpu due to the High cpu due to snmp..
Arun
01-17-2014 04:46 AM
Hi Afroj,
Thanks for the follow up
yes the cpu seems good, im trying to do it for other switch also.
want to find excat MIB's??
is there any performance issue by excluding these MIB's?
01-17-2014 04:53 AM
Excluding the mibs will not impact anything on the device performance , it is just that your monitoring tool will not be able to poll those information ..
take a look at the below link:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800948e6.shtml
to know what OID are ,what they do ,use the below tool:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do
Thanks-
Afroz
[Do rate the useful post]
*******Ratings Encourage Contributors *************
01-20-2014 05:37 AM
Hi Afroj,
I have decresed the MIB's to three,
there is no high cpu spike with these three MIB's also , nee dto find the excat MIB causing this issue
but know the SSH process is causing high cpu
snmp-server view cutdown at excluded
snmp-server view cutdown ip.21 excluded
snmp-server view cutdown ip.22 excluded
Arun
01-20-2014 07:34 AM
Hey man,
Could you summarize this issue. I am currently looking to deploy this in my infrastructure.
01-20-2014 09:18 AM
Hi Arun ,
If SSH is causing HIGU CPU then it can Impact SNMP Engine as SNMP is the least prority process.
Thanks-
Afroz
01-20-2014 11:52 PM
Hi Afroj,
Now only because of ssh only the cpu spike will happen 3 to 4 times a day.
is this because of PI only right?
The PI will do some changes or collecting informations in the switch during the cpu spike.
Arun
01-21-2014 12:04 AM
Hi Arun ,
from the PI prospective , LIcense MIB is a concerne MIB , I have found one BUG with the same filed for PI.
other comman MIB is FLASH MIB, which I have found during the stack decodes.
Thanks-
Afroz
*****Rating encourage contributors ****
01-21-2014 12:13 AM
Hi Arun ,
you can try following on your Cisco PI that is the workaround of the BUG.
Manually update file below,
Open the /opt/CSCOlumos/conf/sam/template.xml, modify the template id=20 (licensePoller)
Update
template id =20
Old:
New:
Note: we can test this out by removing all the SNMP view and apply the above workaorund and analyze the CPU
Thanks-
Afroz
01-22-2014 04:54 AM
Please explain the setting below in GUI of PI
Open the
Arun
01-22-2014 04:57 AM
This is not on GUI. you need to browse to this directory ..open this file in an editor and then make the chnages.
Thanks-
Afroz
01-22-2014 09:28 PM
hi Afroj,
You mentioned in the previous mail that it is a bug.
it is for 1.x or 2.0 version and bug ID please
Reagrds,
Arun
01-22-2014 10:41 PM
Hi Arun,
here you go:
CSCuc72024 License MIB polling : polling frequency increase(Feature removal in 2.0)
Thanks-
Afroz
01-23-2014 02:49 AM
Hi Afroj,
Is there any COPP need to be configured tp privante these type of issue
Now the SNMP engine process not coming but due to ssh we are getting the spikes.
Arun
01-23-2014 03:01 AM
Not 2 sure about this
01-23-2014 05:51 AM
Ok Afroj thanks...
i'll keep posted regarding exact MIB
