Grouping switches by location
Fantaw Tesema
All the switches have the same community strings.
The LMS 3.2  is installed on win server 2003.
I used the following Rule Expression in the rule window:
Device.ManagementIpAddress equals "the ip adr" OR
---- and so on ----
I can successfully see the numbers of grouped switches in the Membership edit window and in the final Summary edit window. But the same number of switches is not appearing in Topology services window and Network Topology window. Can anyone tell me why this is happening?
Thanks in advance.
Tesema
Michel Hegeraat
Level 7
Level 7
Probably you look in the layer 2 topology view.
You should look in the userdefined groups below and there find the group you defined above.
Cheers,
Michel
Thanks. Actually, I am looking in the User Defined Groups, since the groups are made under Topology Groups >> CS@servername >> User Defined Groups. Looked at Topology Services window. Any other idea?
Tesema
