HA on Cisco Prime 3.9
LAN team
I'm trying to rebuild my HA between both Prime node, but the field to register the Secondary server is not available Capture d’écran 2023-09-25 165852.png
Do I miss something ?
Thank you,
Hi, solved now.
I've just do one more time the "ncs ha remove" on primary server and the field become available to restart the HA join process.
Thanks.
balaji.bandi
how are you installed on the secondary server ? have you selected installation option
Will this server be used as a secondary for HA? (yes/no)
Enter yes at the prompt.
BB
LAN team
This one is the primary. I've just remove the HA and I can't set it back.
The status Satus :
Ha configuration mode  : Primary Active
what procedure followed to break the HA ?
BB
Hi, solved now.
Thanks.
